Old 03-28-2012, 09:01 PM   #1
gilley
gilley's Avatar
Re: turndowns at cab
i might just end up runningthem to the front of the back tire but just wanted some input about under the cab.. so thanks for the help guys
70 chevy cst-10
huggar orange
chevy 350
gilley is offline   Reply With Quote
Old 03-28-2012, 09:04 PM   #2
rob32472
use dynamax vt mufflers they are designed specifically to reduce drone......
rob32472 is offline   Reply With Quote
Old 03-29-2012, 12:41 AM   #3
AustinScott
AustinScott's Avatar
under the cab...... yeah..... it is great in theory... but if you drive your truck a lot you will find yourself always thinking about how loud it is...
I had mine dumping right under the cab, no turndowns.
I had to put some 90's on after the mufflers and point them to the side of the truck to even think about enjoying the ride.
Currently have it all redone exiting right in front of the rear tires..
I think they are perfect, loud when you want them to be, but they don't bug you while cruising on the freeway.
BEFORE
AFTER
Hope this info helps you decide, good luck... in the end, its your truck so build it to fit "your" needs!
-=Scott=-
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi,
My 68-SWB Photo Build Thread
All my Google Albums
AustinScott is offline   Reply With Quote
