#26 |
Re: Factory Rear Sway Bar
Do suburbans run a rear sway bar that will work on a half ton?
Posted via Mobile Device |
#27 |
Moderator
![]() Join Date: Oct 2008
#28 |
72 BB C30 Super LongHorn
![]() Join Date: Nov 2002
Found an AfterMarket ADDCO rear sway bar for 73 & up trucks.
Not sure if it is still available. hope its useful... ADDCO #020-202 1'' Rear Sway Bar 1973-91 Blazer 2WD/C-10/C-20 1973-91 Blazer K10 4WD/2DR Tahoe/Yukon 1973-91 Blazer K20, K30 4WD 1973-91 Suburban/Yukon XL 4WD/1500 1973-96 Suburban/Yukon XL 4WD/2500/3500 1973-87 C10/C20/C30 2WD/4WD http://www.jegs.com/i/ADDCO/020/202/10002/-1 ADDCO : http://www.addco.net/aftermarket.htm ADDCO Distributors (per their website) http://02bbfb5.netsolhost.com/distributors.htm
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS
#29 |
SWB 4x4 Collector
![]() Join Date: Jun 2001
Bringing back up an old thread, but there is also the mid to late 70's 3/4 ton rear sway bar that should work on 1/2 tons and 3/4 tons. It was an option on the Camper Edition 3/4 tons. It has a cast piece that wraps around the bottom side of the axle and is held by round ubolts instead of the squared ones. It would have the correct width of the 42.5" spring pad spacing width vs the 40.5" 1 ton spacing.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach):2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
#30 |
Posted incorrectly
Apologies Last edited by RPOZ11; 10-21-2020 at 01:40 AM. |
| Bookmarks |
| Tags |
| bar, rear, sway, sway bar |
