04-01-2012, 08:59 AM | #26 |
Re: Has anyone used the LH8 pan in their swap?
Could you attach a skid plate to the dropmember to protect the pan? What is considered a safe measurment for clearence? My S10 has dropped spindles and I want to be safe on our roads around here.
04-01-2012, 10:23 AM | #27 | |
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
04-02-2012, 11:15 AM | #28 |
On the fast track to nowhere..
You're right. I have a buddy that's in to F-bodys so we measured the pans this weekend. The LH8 is @ 7 3/4" and the F-body is @5 1/2". The truck pan is close to 9". I guess somehow in all of this pan/number research I got them confused
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
04-02-2012, 11:16 AM | #29 |
It doesn't hang low enough to bother me. It's still above the bottom of the framerails so I'll call it good.
04-02-2012, 12:16 PM | #30 |
04-02-2012, 06:59 PM | #31 |
mine....
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
04-02-2012, 07:43 PM | #32 | |
A guy with a truck
Remind me, you're Z'd 3" with stock clamshell engine mounts, right? Does the pan hang down below the stock crossmember at all?
04-02-2012, 07:52 PM | #33 |
yep 3" "z", stock clams, trans dapt mounts, and lh8 pan kit... the red lines are the botom of the control arms, the yellow is the botom of the crossmember, and you can see the bottom of the pan.....bout 3/4" above the crossmember.....if your really worried about the pan, go with the f-body pans....it alot shallower than this one...if I could have a do-over I would go with the camaro pan....
04-02-2012, 08:12 PM | #34 |
A guy with a truck
Yeah, the Camaro pans are bringing pretty good money these days. LH8 pans are cheap and plentiful. And new...
