Old 04-02-2012, 07:21 AM   #1
clb1024
clb1024's Avatar
Frame Preference
I have the choice of building on 2 different frames and wanted to get members feedback on which to use.
Frame #1:
1967 Chevy 1/2 ton 2wd with durms on all 4 corners, trailing arms & coils out back, and a homemade tranny crossmember. No rust. Very straight.
Frame #2:
1968 GMC 1/2 ton 2wd with drums on all 4 corners, leaf spring rear, no tranny crossmember. Painted. Very straight.
I will be using the 67 small window cab for the build.
Favorite quote: "I'm sick and tired of being sick and tired BĦħ@h!" - Drunk guy in one of my accounts
Rides:
67 Chevy C10 LWB Stake Bed(in bad shape)
04 Miti Endeavor AWD(wife's ride)
76 Dodge D100 Club Cab(Hand-me down from my Grandfather)
clb1024 is offline   Reply With Quote
Old 04-02-2012, 08:30 AM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: Frame Preference
It all depends on what you want your truck to be.
The '67 does not have the dimple for the power steering box, but does have coil springs which many like because it gives a smoother ride and is easier to lower.
The '68 has the dimple for the power steering box, but does have leaf springs which give a slightly more stable ride when pulling a trailer. It is a little harder to lower.
You did not mention the gear ratio of the rear-ends, that could also make a difference in which one to chose.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 04-02-2012, 09:04 AM   #3
clb1024
clb1024's Avatar
The both frames have power steering installed. As for the axles the 67 has the baby inline 6cyl and 3 on the tree, the 68 I was told it has a mini spool wrapped with 3.73's. I don't mind swapping the axles from 1 to the other.
Rides:
Old 04-02-2012, 10:28 AM   #4
RenoKeene
Florida Edition
RenoKeene's Avatar
Welcome aboard from Central Florida (Lake County)!
I would use the 67 with the coil spring setup for all the above mentioned reasons. Glad to see you building a small back window unit, I'll be doing the same this summer.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 04-02-2012, 06:54 PM   #5
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Welcome to the board from Texas
Coils springs...enough said
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 04-02-2012, 10:17 PM   #6
longbed67
longbed67's Avatar
'67 coil springs and same year as the build will be.
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
