Closed Thread
Old 04-25-2012, 08:29 PM   #5151
62 Barnfind
62 Barnfind's Avatar
Re: What did you do to your truck today?
Installed the generator wiring harness.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline
Old 04-26-2012, 01:52 AM   #5152
bobbylast
bobbylast's Avatar
Originally Posted by 1963c-10 View Post
Are you shaving your own whitewalls?
ive decided on buying some porta walls instead. my bullets didnt fit so i shipped them back. i'm trading some locksmith work to a muffler shop in town this week and i'm getting my stainless shorties hooked up and tucked in under the truck.
If you used to be...then i guess you never were.
bobbylast is offline
Old 04-26-2012, 02:02 AM   #5153
wp1968
wp1968's Avatar
tried to arrange the body of my truck to look like its actually a truck and not just a body sitting next to my house.(keep the neighbors happy) need to still stick some tires under it
my build:::patina 67 c10 chopped/bagged/z'd:::
http://67-72chevytrucks.com/vboard/s...d.php?t=521253
wp1968 is offline
Old 04-26-2012, 06:26 PM   #5154
big_rig
I added oil... She's sucking a lot back these days. Then drove it to make sure some of that oil went to good use.
big_rig is offline
Old 04-26-2012, 08:30 PM   #5155
gimmy 64
is that what they call yard art? i like it but i don't think my HOA would go for it
gimmy 64 is offline
Old 04-26-2012, 09:02 PM   #5156
CRGRS 66
CRGRS 66's Avatar
Originally Posted by markeb01 View Post
Is this what you are looking for:
3/16:
http://www.summitracing.com/parts/RNB-118-045/
5/32”
http://www.summitracing.com/parts/RNB-118-005/
Perhaps having a Dorman part number will help you find one clip locally instead of 25 which you'll probably never use. Summit has more listed. They range from 1/8" to 5/16".
Markebe
Exactly what I "was" looking for. This is what I came up with though...
CRGRS 66 is offline
Old 04-26-2012, 09:08 PM   #5157
CRGRS 66
CRGRS 66's Avatar
1/4-28 rod, and a rod yoke, what do you think?
CRGRS 66 is offline
Old 04-26-2012, 09:09 PM   #5158
62 Barnfind
Started sanding and pulling dents.
John Z
62 Barnfind
Old 04-26-2012, 09:14 PM   #5159
Kas66c10
Kas66c10's Avatar
Tried to fix gas gauge with new sender/wire. Still no luck. Barely moves off empty. Wonder if I have 90 ohm gauge with 30 ohm sender?
Try again tomorrow.
Kas66c10 is offline
Old 04-26-2012, 09:50 PM   #5160
markeb01
Senior Enthusiast
markeb01's Avatar
Originally Posted by CRGRS 66 View Post
Markebe
Good fix, and more dependable than the clip. Other than being a different style heim joint, that's the same setup I ran for 20 years until recently switching to a cable style gas pedal.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 04-26-2012, 10:31 PM   #5161
CRGRS 66
CRGRS 66's Avatar
hey markeb, just going through your build thread, very nice truck, and very enjoyable read, actually just on page 2.
CRGRS 66 is offline
Old 04-26-2012, 10:31 PM   #5162
rendus
rendus's Avatar
Replaced my column shifter bushings and aligned the shifter arms. Put the name decals on the front bumper and tailgate.
'66 C10 250 3-on-the-tree
'68 Galaxie 460/C6
'74 914 2.0
rendus is offline
Old 04-27-2012, 12:18 AM   #5163
K5 Addiction
K5 Addiction's Avatar
Mounted & plumbed my new 1961 Schlitz keg in the bed of my truck. Tomorrow the stock tank comes out & the old fuel filler neck come gets shaved off.
K5 Addiction is offline
Old 04-27-2012, 12:49 AM   #5164
mud.man.rj
mud.man.rj's Avatar
Now the cops will pull you over and say,,what's in the keg.
mud.man.rj is offline
Old 04-27-2012, 01:40 AM   #5165
markeb01
Senior Enthusiast
markeb01's Avatar
Thanks for the interest and feedback! I try to keep up with the various build threads, but there are so many cool things on this site every now and then I'm surprised to find an ongoing thread I've never seen before.
markeb01 is offline
Old 04-27-2012, 03:59 AM   #5166
Woogeroo
rotated the tires, front to back.
pulled the drums and checked the shoes for wear.
checked the fluids while I was dirty.
-W
Woogeroo is offline
Old 04-27-2012, 09:55 PM   #5167
robber grin
Started pulling the front torsion-bar crossmember - 3 bolts out and a bunch to go.
robber grin is offline
Old 04-27-2012, 10:09 PM   #5168
CRGRS 66
CRGRS 66's Avatar
I added a second yoke at the carb, and switched to socket head shoulder bolts. I am very pleased with the result. A before, and an after for ya
CRGRS 66 is offline
Old 04-27-2012, 10:14 PM   #5169
CRGRS 66
CRGRS 66's Avatar
the new intake, coil, and painting of some of the bits and pieces helps too!
CRGRS 66 is offline
Old 04-27-2012, 10:57 PM   #5170
dantimdad
dantimdad's Avatar
ordered 108 button head stainless steel bolts and washers in different sizes to replace all the visible bolts on the engine, inner fenders, fenders, etc.
Even if my painting sucks, the bolts will look good!
We finally decided on the color scheme - dark purple with the tan silverado interior. Going to fab up a vinyl over fiberglass shell dash cap and headliner and cover the door panels in the vinyl as well.
I will be so glad to get all the patch panels in so we can start, sanding and painting.
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline
Old 04-27-2012, 11:46 PM   #5171
64shortbox
64shortbox's Avatar
dantimdad,
For your button head stainless bolts, you might want to check out the Mc Master-Carr catalog and get some of the clear nylon flat washers to place under the button head bolts for the inner fenders etc. to protect the paint from scratching or marring. Just a thought.
64shortbox is offline
Old 04-27-2012, 11:51 PM   #5172
CRGRS 66
CRGRS 66's Avatar
Terry
Saw the pictures you linked me to, very, very nice looking truck sir!
They all need some work, no matter how good the look.
I am off to bed now, want to get an early start at finishing up me intake swap, and get the old girl back on the road, need a fix!
Craigerr
CRGRS 66 is offline
Old 04-28-2012, 12:25 AM   #5173
dantimdad
dantimdad's Avatar
64shortbox,
Thanks for the tip!
I will order some.
Steven
Old 04-28-2012, 08:36 PM   #5174
dean jendro
Old and crusty
dean jendro's Avatar
Got some parts back from powder coat this week so I did some assembling.
This is what the finished grill I've been working on will look like. I had to remove the headlight buckets from the C50/60 grill and use the C10 ones so as long as they were out I powdered them black and just used small screws to remount them into the grill. The backside shot shows how I attached the letters to the center section. I think it came out real nice.
I also assembled my power brake assembly. I went to the local yard and sawed off a pedal off a late model Silverado, did the same to my pedal then welded the longer pedal to my brake arm. All was powder coated, reassembled and a new rubber pad from the local Chevy parts store installed.
dean jendro is offline
Old 04-28-2012, 09:00 PM   #5175
CRGRS 66
CRGRS 66's Avatar
I am not much for mods, but let me tell you... that grill looks absolutely fantastic... how much would you take for it
Today, I did not accomplish too much... Mom in Laws 80th, happy birthday to you, bye now!
I did however get my distributor back in, and ran a bit of new fuel line. Need to sort out the top rad hose, and the routing of the spark wires. I think then it is time to get her back on the road.
CRGRS 66 is offline
Closed Thread
