#15 |
Re: how to install cab molding on my 77
I used the tape on mine a year ago, ended up taking the trim off, almost impossible witho out bending the trim, held great. For the gap your asking about i used foam tape that was sticky on one side,they have it at lowes and use if you installing toppers on beds, then the surface was flat, i put thin tape on the top and bottom and then a piece down the middle worked great. I plan on doing that again when i re-install the trim.
1981 Dodge D-150 (under construction) 2007 Chevy Suburban 2010 Dodge Charger R/T 1980 Kawasaki KZ 440 2004 Harley Sportster 1200 |
| Bookmarks |
| Tags |
| 77 chevy, cab band, cab corner, molding |
