Old 05-18-2012, 03:25 AM   #1
scum1
scum1's Avatar
73+ drop spindles on 71-72
I read a thread asking a similar question a while back and now i cant find it. I currently have the 71-72 crossmember/arms/tierods/ball joints etc..
theres some 73+ 3" drop spindles on craigslist...is it true that i can use the 73 drop spindles on the 71-72 components if i just switch the outer tie rod to the 73' type and change to 73' lower and upper ball joints.
i also heard that runnin 3" drop spindles with 15" wheels might require shaving of the lca for full steering ablility.
can anyone confirm this for me? thanks
scum1 is offline   Reply With Quote
Old 05-18-2012, 03:37 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 73+ drop spindles on 71-72
Lower ball joint is the same as the 71-72.
Change the upper ball joint and the outer tie rod.
Yes,... minor trimming of the lower control arms is necessary with 15" wheels with more than 3.5" of backspacing.
Keith
Convert to disc brakes.
Old 05-18-2012, 03:49 AM   #3
scum1
scum1's Avatar
cool thanks for the response!
