Old 05-26-2012, 07:11 PM   #26
SS317
SS317's Avatar
Re: 66 rear bag question
STill leaking, it's either the bag or the little plug in you push the air line into. Anyone have any suggestions? Are you suppose to put anything on the airline when you plug it in?
1966 Chevy C-10
350 Engine
700R4
SS317 is offline   Reply With Quote
Old 05-28-2012, 11:19 AM   #27
Pro Performance
Pro Performance's Avatar
Just make sure the air line is cut very clean and square. If it is cut on an angle, it could cause it to leak.
Take some soapy water in a spray bottle, and spray all connections. If it bubbles, you have a leak. You can either turn the fittings a 1/4 turn to see if it seals, or remove and re-apply teflon tape and re-install.
Pro Performance is offline   Reply With Quote
Old 05-28-2012, 11:25 AM   #28
SCOTI
SCOTI's Avatar
x2.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-29-2012, 10:39 PM   #29
SS317
SS317's Avatar
OK, Kit installed and it ROCKS!!! I couldn't like it better. My truck is stable driving down the road now, even pulling my mowing trailer loaded up heavy.
Special thanks to Travis at Pro Performance. He took great care of me and I will do business with him again.
1966 Chevy C-10
350 Engine
700R4
Old 05-30-2012, 12:47 AM   #30
Pro Performance
Not a problem at all... Good to see you got it all installed and are enjoying it!
- Travis
Old 05-30-2012, 01:53 PM   #31
PBFAB.COM
PBFAB.COM's Avatar
Definately a great individual and excellent place to deal with, especially since they sell our stuff.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 07-22-2012, 01:40 AM   #32
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I have a 65 on a 62 frame.
I want to keep it at the height it is in the pic below.
I want this to be the height for day to day driving.
Because it's on a 62 frame, the shocks are already in the back.
What do I need as far as bags and cups to keep this height?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 07-22-2012, 02:15 PM   #33
SCOTI
SCOTI's Avatar
Typical recommended rear bags are the 6-6.5"dia variety which yield about 6-7" tall @ ride height. The 'hats' used to simplify installation can vary in height depending on the manufacturer but are usually about 1-1.5" tall.
Take a measurement of the height of your current spring w/the full weight of the truck on the suspension & compare the diff for your answer.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
