Old 06-02-2012, 10:03 PM   #1
Sabaka454
Sabaka454's Avatar
Re: Fuse Box Help
What is the voltage at IGN vs CTSY?
Sabaka454 is offline   Reply With Quote
Old 06-02-2012, 10:30 PM   #2
TheApocalyptican
TheApocalyptican's Avatar
Re: Fuse Box Help
Originally Posted by hatzie View Post
There's a splice near the bottom of the steering column that connects The pink fuse panel and bulkhead wires to the ignition switch. I'd look there for a loose connection.
I'll have to check that.
Depending on conditions ctsy is 12.8 to 13.8. IGN is 11.8 to 12.1 with the lower and higher numbers being corresponding with each other.
1995 Suburban K2500 454.....off road & towing
1999 Astro, work van
2006 Silverado 2wd 5.3 w/4.5" lift and 33s
TheApocalyptican is offline   Reply With Quote
