Old 05-11-2012, 10:46 AM   #26
crazeetxn
crazeetxn's Avatar
Re: Tire Sticking Out
Originally Posted by silvereagle07 View Post
I think 1bad87 is on to something. I noticed all of my squares in the yard stick out on the drivers side. It's really noticeable on my slammed 84 GMC.
This may play into our favor when we're trying to buy one "Uh, somethings wrong with your tire here....may need to take $500 - $1000 off cause I'm gonna have to fix that"
1st - '68 long bed
2nd - '81 SWB
Now - '86 SWB, Edelbrock 1406/stock 350/700r4
crazeetxn is offline   Reply With Quote
Old 05-11-2012, 11:00 AM   #27
'82 steppin
'82 steppin's Avatar
Passenger side
Driver side
'82 steppin is offline   Reply With Quote
Old 05-11-2012, 11:36 AM   #28
Pro/StreetPete
Pro/StreetPete's Avatar
This thread is ......well it's interesting, being new around here I better be careful what I say..... there are way to many veritable's to the answer as responses indicate...
"You're only as good as the people you keep around you"
Pro/StreetPete is offline   Reply With Quote
Old 05-11-2012, 12:32 PM   #29
Edahall
It's possible that it was involved in an accident and the frame was shoved over to one side. Then when it was repaired, the front clip was scooted over the other direction to compensate. You might want to take some measurements between the frame and the fender on each side and compare.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 05-11-2012, 12:59 PM   #30
esbstuff
You may check to see if the body has been placed over to the passenger side some. The appears to been scooted over alittle due to the gap between the fender and the bumper as highlighted in the inclosed picture...
You may also check some of the bumper adustment also.. There is 1/2 inch to 3/4 inch side to side adjustment.
esbstuff is offline   Reply With Quote
Old 05-11-2012, 01:03 PM   #31
esbstuff
BTW For everyones infomation... This post in on 4x2's.
4x4's have a wider track in the front than the rear from the factory.
Old 05-11-2012, 02:22 PM   #32
rwhit57
rwhit57's Avatar
I think I noticed the truck in question has aftermarket wheels, I would still check back spacing. The only time I've ever noticed anything like this was a truck I had, when I checked it out it had one 8" rally wheel with different back spacing. I don't know how many different rally wheels there are but I have seen several. The only other thing than the body parts being moved, could be some kind of aftermarket replacement spindle, but I'm doubting that. It is interesting though.
"Whoever said money can't buy happiness has obviously never seen a speed shop!
rwhit57 is offline   Reply With Quote
Old 05-11-2012, 02:25 PM   #33
rwhit57
rwhit57's Avatar
4x2's do also. I think it's almost 3"
Old 05-11-2012, 05:21 PM   #34
motornut
78K & 79C Jimmys
motornut's Avatar
jimmys too?
could just be how pics get reduced on here, but does the gap I pointed to look different?
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 05-11-2012, 06:14 PM   #35
'82 steppin
Originally Posted by motornut View Post
jimmys too?
The wheels are exactly the same I changed the wheels with different set and the same problem is there and mine is two wheel drive
Old 05-15-2012, 12:41 AM   #36
1LowToy
I had a bit of the same problem. I measured everywhere. I had the body shop straighten the left front frame horn and he said that the front end was off by 1/8" but that was not the issue. I found that the left side had way too much camber and the right side had way too little. Most alignment shops will not be too critical as they are production shops. Meaning get it in and get it the vehicle out in record time, unless you buy a whole front end rebuild that is usually not necessary. Fine tuning the aliginment may be helpful for you. I've seen several of these trucks with this camber issue including mine.
1LowToy is offline   Reply With Quote
Old 06-25-2012, 05:57 PM   #37
BrookelynnGreen
BrookelynnGreen's Avatar
well on my red truck the fender is dented in and the bumper is also slightly pushed in because i got stuck in a ditch. the problem was there before it happened. I tried switching tires and the problem is still there. but one thing i did notice was that on my driver side the ball joints were in ****ty shape, but on the passenger side the ball joints were fine. you think if i replace the ball joints on the driver side it may tuck the tire back in where its suppose to be???
-Samuel
"Knowledge Is Power"
BrookelynnGreen is offline   Reply With Quote
Old 06-25-2012, 06:43 PM   #38
86c20
86c20's Avatar
guys i know a man all he does are these trucks. he told me that out of factory the front clips could be wrong by 1" and the suspention wrong up to .5. never mind the beds
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 06-26-2012, 12:58 AM   #39
Square_78
Square_78's Avatar
Gotta love that kind of quality control coming out of the major factory! hahaha!
Square_78 is offline   Reply With Quote
Old 06-26-2012, 07:29 AM   #40
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
The travel path for our truck is unique!! The front travel path is 1" than the rear. How that 1" is shown, is different from truck to truck. GM engineered them that way. I assume it was for a more stable front end. Replacing the A-arms with aftermarket tubes or modified stock arms is the only way to remove the extra gap. This difference is why wide front tires rub the fender.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 06-26-2012, 07:47 AM   #41
C-10 simplex
Still no resolution?
Visually check the length of the left a-arms and compare to the right a-arms.
C-10 simplex is offline   Reply With Quote
Old 06-26-2012, 10:55 AM   #42
Rich84
Rich84's Avatar
Tires sticking out crooked, whole trucks leaning to one side or the other, bumpers sticking out too far on one side vs. the other, front tires that stick out farther then the back.....What the hell am I driving?? I'm afraid. What if your truck was built on a Friday after lunch.
Rich84 is offline   Reply With Quote
Old 06-26-2012, 12:25 PM   #43
Keith Seymore
Keith Seymore's Avatar
On 4wd it is so the rear tires track in virgin material, rather than in the ruts created by the front tires - for better tracking off road.
On 2wd it was simply a result of the packaging required to get all of the suspension characteristics to work out.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 06-26-2012, 12:26 PM   #44
Keith Seymore
Mine was built second shift on a Monday - and seems to be holding up ok...
K
1979-1986
1986 - 2019
Old 06-26-2012, 05:18 PM   #45
INSIDIOUS '86
INSIDIOUS '86's Avatar
Mine was prob built by this guy^ and the doors still shut with so muçh as a sneeze
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 06-26-2012, 05:45 PM   #46
cory d
cory d's Avatar
i have played around withe the doors a bit and i have gotten them better but i still have to slam them
cory d is offline   Reply With Quote
Old 06-26-2012, 07:18 PM   #47
cmyc5575
Pls let us know what you figured out what the issue was with the wheel and such very curious to find out! im not having problems with mine like that, but my bed is sticks out on the passenger side more and tucked behind the cab on the driver side. of course the thing was hit behind the wheel fender where the tailight is at on the driver side, but idk if the bed being hit as little as the dent is would bend the whole bed.
cmyc5575 is offline   Reply With Quote
Old 06-26-2012, 07:46 PM   #48
cory d
cory d's Avatar
loosed up the bed bolts (grab the pb blaster) and see if you can center it. you should have a bit of slop to work with. more then likely it will stick out a little on both sides though
Old 06-26-2012, 07:51 PM   #49
cmyc5575
LOL what is PB blaster? I new to all this! I dont care if it sits out on both sides of the cab, just as long as the spacing is the same on both sides.
Old 06-26-2012, 08:52 PM   #50
baclay9
PB blaster is a spray on product that works its way into nuts and bolts to make it easier to break them loose. You should be able to get it at any auto parts or tool store.
baclay9 is offline   Reply With Quote
