Old 07-04-2012, 02:34 PM   #201
68 short step
Re: project BIG RED (gen3 on air)
Originally Posted by RaceAGMC View Post
Yet another sweet build. Any chance you have part nuMbers for all the steering hose fittings. I am working on plumbing my steering I also have a Gen III swap in my truck with a factory power steering chassis.
you are in luck, i just PMd someone that ezact same question a few days ago...
i make my own lines, i use AN fittings from summit.. the power steering resovior is 16mm x 1.5 o ring earl part # 991955erl..
for the gear box on the truck (assuming it is the stock unit) it is 11/16-18 earl PN 991950erl and 5/8-18 PN 991947erl....those are for a -6AN line, which is the size id recomend
then pending on how you route the lines, you'll need a few 90*, maybe a streight, or ???????.... normally for these style trucks, with the stock inner fenders, i get (in addition to above P/Ns)... Also on all powersteering ftngs id recomend earls brand....the summit brand cant handle the pressure
(1) 90* -6AN
(2) 120* -6AN
68 short step is offline   Reply With Quote
Old 07-04-2012, 03:51 PM   #202
RaceAGMC
RaceAGMC's Avatar
Thanks so much, I happen to have some extra -6 line leftover from plumbing my fuel system, I will order up those fittings and get it all fixed up.
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
Old 07-07-2012, 08:18 AM   #203
1968gm
Very cool, keep up the good work!!!
1968gm is offline   Reply With Quote
Old 07-07-2012, 12:01 PM   #204
70onB.A.D.'s
70onB.A.D.'s's Avatar
Great Build man, subscribiing to this one. Any chance any body can stop by and see the progree I am only about 30 min away.
70onB.A.D.'s is offline   Reply With Quote
Old 07-07-2012, 09:44 PM   #205
68 short step
well, if you come to some of tulsas car show, you may just see it.....
here are some more progress pics.... i ran the wiring for the air managment, and didnt want to have a groumet with all those wires coming in the cab, so i went with a 1/4 lock bulkhead... the connection will be hidden under the seat, and should the cab need to come off, its a simple twist to seperate the wiring going into the cab...
Old 07-07-2012, 10:21 PM   #206
trashmanryan
68 short step, I've looked through all your builds. Awesome work man!
trashmanryan is offline   Reply With Quote
Old 07-07-2012, 10:30 PM   #207
67cheby
67cheby
67cheby's Avatar
That is to cool , where are they from ?
67cheby is offline   Reply With Quote
Old 07-07-2012, 11:04 PM   #208
gringoloco
A guy with a truck
gringoloco's Avatar
Looks like aircraft parts. Cool!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC).
gringoloco is offline   Reply With Quote
Old 07-08-2012, 05:24 PM   #209
68 short step
yelp they are... ill have to look at the bag, to see where they came from...
Old 07-15-2012, 12:45 AM   #210
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Mcmaster car has those connections as does d.i.yautomotive..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
