Closed Thread
Old 07-12-2012, 03:36 AM   #26
VA72C10
VA72C10
VA72C10's Avatar
Re: Speedwarning tach dash with wiring and buzzer choose your options!!!
Originally Posted by DeadheadNM View Post
Definitely interested. Sounds like $750 shipped for the cluster as I've described plus $145 for a wood grain bezel and glovebox door (woodgrain applied to the aluminum panel - not whole door) from CSM. Correct?
If so, lets see some pics of the cluster components when possible. Thanks, Pete
Sorry for the delay. Here are the components. Let me know if you have any questions.
VA72C10 is offline
Old 07-12-2012, 08:32 AM   #27
DeadheadNM
Carpe manana
DeadheadNM's Avatar
No worries I appreciate the pics. I don't see the vac gauge/vac lens. 80lb oil gauge? OEM printed circuit? Thanks, Pete
DeadheadNM is offline
Old 07-13-2012, 03:05 PM   #28
VA72C10
VA72C10
VA72C10's Avatar
is that all I forgot? wow, serves me right for taking pics and posting so late at night. I will get the correct pics in a few minutes...
VA72C10 is offline
Old 07-13-2012, 04:07 PM   #29
VA72C10
VA72C10
VA72C10's Avatar
Here are the rest of the pictures. The printed circuit has no burns but does have some separation as you can hopefully see in the picture holding it to the light. I personally would use a new reproduction since the circuits are 40+ yrs old.
VA72C10 is offline
Old 07-13-2012, 04:27 PM   #30
VA72C10
VA72C10
VA72C10's Avatar
Here is the vac lens (new). My only other isn't up to par with the rest of the dash. I do have another good original printed circuit without burns or separation but is was scratched at some point (likely removal from the truck) so its not perfect either.
VA72C10 is offline
Old 07-13-2012, 04:28 PM   #31
VA72C10
VA72C10
VA72C10's Avatar
The white circuit is made in the usa. The green imho looks better (not that it is seen) but is an import
VA72C10 is offline
Old 07-13-2012, 08:13 PM   #32
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Looks great. I would defer to your judgement on the printed circuit and use a repro if you think best (USA repro). If OK with you I'd send half now half when complete for total of $750 shipped on the tach/vac s/w 80lb oil gauge cluster all OEM gauges with buzzer and harness. Even though I'm sober now I'd still consider the woodgrain from CSM as discussed. Let me know when possible. Thanks, Pete
Old 07-13-2012, 10:53 PM   #33
VA72C10
VA72C10
VA72C10's Avatar
Half now half when complete will work fine. I don't have any of the csm panels so its best to go direct to him so you don't pay shipping twice unless you want me to install the bezel w/ adjuster knob. The bezel is 95 and glovebox insert is also 95 (plus shipping) so it is 190 plus shipping for those. If I'm cutting the bezel id need 25 mainly because of the risk when cutting that hole. I cut the woodgrain first with a new utility blade then drill the hole through the plastic bezel. Pm sent with payment info.
VA72C10 is offline
Old 07-14-2012, 09:00 AM   #34
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks Jonathan. For now I'll go with a new woodgrain bezel as per post #1 and hold off on CSM. PM sent. Thanks, Pete
Closed Thread
