Old 07-25-2012, 09:44 PM   #1
daveytruck72
Rear spring position between trailing arm and frame
Well finally got frame repaired and all pieces bolted in place but I find no info on exact postion of spring in the cups No torque specifications either in the old chiltons manual I have.
Any help or pics would be appriciated
Thanks!
daveytruck72 is offline   Reply With Quote
Old 07-26-2012, 10:06 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Rear spring position between trailing arm and frame
Welcome to the forum daveytruck72. Lets bump this to the top and see if we can get a reply.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-26-2012, 11:49 AM   #3
69gmcc10
69gmcc10's Avatar
Davey can you be more specific please? I think you are asking for the position of the bolt hole the rear spring mounts to the frame. If that is the case, the spring and shock mount cross member is indexed off of the oval hole on the side of the frame. If your repairs to the frame have eliminated the hole it is 47.25 inches back of the trailing arm cross members front rivet.
Here is a diagram of dimensions for both short and long bed trucks, the bolt that holds the spring to the frame is in the center of the cross member marked at 102.25 (lwb) or 90.25 (swb). Here also are a few photos of when I did this last week on a leaf to trailing arm conversion.
Hope this helps.
69gmcc10 is offline   Reply With Quote
