![]() Join Date: Mar 2012
Re: GMC and Chevy TF doors slightly different
Interesting about the hinge bolts. My '57 has fine thread bolts on both doors. The driver's door is original and the original passenger's door, which I removed, also had fine thread. The replacement RH door is from a '55 'burban and I thought someone had hacked it up by putting coarse thread bolts in so I cut the plate with the fine nuts out of the original door and welded it into the new one.
How about the countersunk screws which attach the inner panel? Is clutch head correct? Or Phillips? I've seen both. |
#2 | |
