Help me on an Order from Top Banana?
This first photo is the drivers side.
I need to repair the floor section that you can see has a hole in it as well as the metal piece that goes in behind the outer rocker panel all the way to the back. I'm not 100% certain that I've found the right part, I assume the part displayed is slightly different from what I will receive. (maybe they only had a picture of the same part but for a different year) The part is called a "Driver Side Cab Floor Exterior" and states that it is for the 67-72 chevy pickups. I just want to know if what I found is correct. It costs $57 on Top Banana. Any input is appreciated.
Calder |
![]() Join Date: Oct 2009
Re: Help me on an Order from Top Banana?
yep, tough call - I'd ask them if it's exactly what's pictured - if yes, I'd look elsewhere - if no, then I'd ask them about their return policy, and if it's acceptable, give them a shot.
Lots of places put generic photos of the general area - I find it annoying, but it's somewhat common. |
#3 | |
Calder |
Anyone have any other info?
Calder |
That's the part also you need rocker too. I did the same with my floor
Pancho 69 c/10 step side 454/400 with 3.07 Last edited by c1069; 09-05-2012 at 10:50 PM. |
Also called Floor outer complete section, left side
http://www.classicparts.com/1967-72-...info/45%2D945/ Posted via Mobile Device
Pancho 69 c/10 step side 454/400 with 3.07 |
Thanks you guys! I already have the other parts in my cart and I know that I have all of those correct. I am going to put in my order, thanks for the fast feedback
Calder |
I hope that's for some other application,because it sure isn't made the same as OEM. isn't there a longer part you can get that goes to the back of the cab? I haven't had to buy these parts,but I believe they are called outer floor extensions.
Well the order has already been placed so I guess thats the only way to know for sure, I will leave an update when the parts arrive.
Calder |
#10 | |
I had to buy the same part from board vendor. That will work goes along all the floor section.
Thank you for the reassurance, it's not a cheap part when compared to the other parts. (rockers, cab corners...etc.)
Calder |
Bought mine from AutoMetalDirect.com and the parts were exactly like your original. Bonus for me is that they are local.
![]() Join Date: Dec 1999
The picture showing is 60-66 not 67-72
Thats what I was thinking!
Calder |
#15 |
Dang! As I was scrolling down I was hoping no one else would know. Tim beat me to it and he should know. I found someone selling these same pieces on CL yesterday. I shopped it for comparison so I recognized it right off. Yup, the pic is 60-66.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
#16 |
![]() Join Date: Sep 2012
Ditto on the above . You should put the front and rear cab mounts in also . Hell your right there working anyway . It's going to need it.
