Badass
low as possible
want to go as low as possible static drop. and still have it driveable. i dont plan on halling anything with it. ive already have 3inch lowering springs. 1 coil cut off the stock coil springs and just a flip kit out back. i know ill need a c-notch kit. but what else do you guys run to get so low? like 6/7 drop im looking into. also what do you do for inner fenders?
pics of your ride would help ![]() here is mine as it sits now
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
Slots go on anything!
Re: low as possible
3" spindles, cut stock coils, flip kit w/ C notch, and rear shackles = 6/8 static drop. Mine is a '74, and I have inner fenders. I think the earlier trucks have bigger inners, though. I think you are going to have to go to spindles to get the front lower.
1974 Jimmy- 5.3/4L80e/NP241 |
Cruzzzn' Vet
Re: low as possible
Pics out of the grass and on a flat surface would give us a better idea of how low you are
![]() ![]() ![]() Uploaded with ImageShack.us |
Badass
Re: low as possible
sorry lol here is some off the grass
![]() i switch between the two sets of wheels 235/75/15 rallys 245/45/17 - 315/35/17 eagle alloys
It'd be alot cooler if you did
Re: low as possible
get some drop spindles. Out back, shackles will have you cutting the bed support, but thats an option. you could also move the spring perches up on the frame, that's pretty easy if you have a shop. Finally, you could add a block if you already have a flip kit.
#6 | |
Badass
Re: low as possible
i my do drop shackles for the rear along with a c-notch
yeller
Re: low as possible
Trucks with the longer 56" springs will not require the bed support to be notched.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
Badass
Re: low as possible
yes i know this. mine has the shorter of the 2 springs. the bed will have to be notched. no so big of a deal..
just worried about the front
yeller
Re: low as possible
5-6 is as low as I would go. I would put 3" spindles and 2" springs...cut 1/2 coil off each if 5" isn't low enough and you think you have room. Tire size will be the deciding factor.
Re: low as possible
you can cut a half coil off or a full and relocate the leaf hangers higher up. FREE
![]() almost free, you will need nuts/bolts for the hangers
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
Re: low as possible
First thing you need to do is measure the lowest point of your lower control arms(under the bushing shaft) to the ground, then measure the top of the front tires to the underside of your inner fenders to see how much room you have left to lower the truck with your current rim/tire configuration.
John 82 Chevy Silverado 350ci/TH350 ![]() |
Re: low as possible
6-7 daily driver.
![]() 3" djm spindles and springs. A crappy djm flip kit and western 2" drop shackles Don't get djm rear kits anything Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#14 | |
Badass
Re: low as possible
what size tires ? how do it ride? do you have inner fenders?
#15 |
Re: low as possible
245/50/16 up front and 295/50/16 rear.
The three inch front spring is to soft for my taste and the shocks are crap not tw mention I have a lot of work on the front suspension to make it handle like a vette lol but I'm not chattering my teeth or bouncing everywhere. Use a 3/4 ton cut spring up front and good shocks to keep your control arms off the ground and run shock extenders in the rear with as soft valves shocks you can get. And a one ton front swaybar with urethanes in the middle and rubber on the outer Posted via Mobile Device
#16 |
Badass
Re: low as possible
no rubbing on the inner fenders?
might try the 3/4 ton springs. remeber reading people doing that
#17 |
misshape grape
Re: low as possible
Spindles, chopped coils. Removed leafs, flip and notch, spring hangers mounted higher on frame. Not sure of the drop, but it's low, and streetable. A little rub on lock to lock turns with my tires. 20" wheels
Posted via Mobile Device Posted via Mobile Device
Don't you just love rumors? I always find out stuff about myself that I had no idea I even did.. |
#18 |
misshape grape
Re: low as possible
Never had an issue, although the roads in north florida were always good! It's still in Fl, haven't brought it to Wi yet, but we'll see. Haha.
#19 | |
Re: low as possible
#20 |
Re: low as possible
There is a lot of good info in the "make it Handle" thread in the suspension forum also. I have a set of the 3/4 ton springs waiting for when I rebuild the front end on my truck as well (during the engine swap). I have the heavy duty spring packs in the rear and the front springs are just stock, but cut. The truck rides amazingly well. If I didn't have a 75 mile commute every day, it would probably be my daily driver. I am hoping that the LS swap will get me a lot beter mileage, and it will see quite a bit of road time. I have 245/60 15's on the front, and 255/70 15's on the rear.
#21 |
Re: low as possible
Jonboy...Truck looks awesome.
#22 |
misshape grape
Re: low as possible
One of my favorites!
#23 |
Re: low as possible
how do the 3/4 ton springs compare the the 1/2 ton springs? i feel the front of my truck it too soft for the small block and sm465, could be the shocks, they are monroe gas magnums.
it would be about 15 bucks a spring at picknpull. that doesnt sound bad as long as i can get them off safely. what do you guys think about 2 coils, flip and 2" shackles? right not i have 1.5 coils cut and a flip kit this is how it is now but i feel it need to be lower ![]()
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread Last edited by cory d; 09-06-2012 at 10:56 AM. |
#24 |
Re: low as possible
Thanks for the props, guys. I need to get the truck out and drive it a bit before I tear it all back apart.
Cory, the 3/4 ton springs are heavier to carry the weight of a big block and heavier frame. The spring rate is a lot higher, making them stiffer. Ideally, I want to change out the rear suspension in my truck to the earlier "truck arm" setup, similar to a 60-72. It will happen (hopefully) eventually.
#25 |
Re: low as possible
i may just try that then. i noticed a big differenence after swapping the th350 out for the sm465, that thing is a giant chunk of iron. with 2 dirtbikes in it, it will hit the frame so i will have to notch it too i guess
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread Last edited by cory d; 09-06-2012 at 11:15 AM. |
