#876 |
A guy with a truck
Re: How to: Ruin a perfectly good C10
Squirted some color on a few small parts today--really liking this VHT epoxy satin black. It has the perfect sheen and lays out really nicely. The control arms and rear disc brackets will head to the powder coater next week...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#877 |
![]() Join Date: Oct 2010
Nice parts ! and painted pieces are lookin good too. Vht is a good product, I use it and duplicolor as well. keep up the good work !
John Mild Custom 68' Work Truck Build Facebook LoL 1977 Trans Am (Project) 1965 Chevelle (Project) |
#878 |
Still Learning
More nice parts. The paint looks good.
Posted via Mobile Device |
#879 |
Looking good! I like to see the Porterbuilt parts! My next build will have some for sure
-Calvin http://67-72chevytrucks.com/vboard/s...d.php?t=512270 my build, tube chassis and LS2 How I keep the truck shining, Detail thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697902 |
#880 | |||
A guy with a truck
![]() Posted via Mobile Device
#881 |
A guy with a truck
Pulled the 'bags and installed the ECE 6" drop rear coils. Man, this thing is L-O-W...
The coils slipped right in like they belonged there and in conjunction with my 1.5" blocks give me 7.5" of rear drop, which is about 1.5 lower than where I had the airbags set before for the 'just right' rake. Not sure what the plan of attack is at this point, as I kinda like the lowered look, but would have to re-work shock mounts, bumpstops, and maybe exhaust to get it right--not to mention the work involved in getting the front down another inch to match ![]() The ride is different--definitely feel more of the road than with 'bags, but not necessarily in a bad way, except when I hit a larger bump and it bangs the bumpstops. If it stays at this height, I'll fix that so it won't be a factor...
#882 |
A guy with a truck
Here's before and after measurements of the rear wheel arch, as well a side view showing just how re-donk-u-lous it looks with the a$$ dragging the ground. I am NOT a fan of the 'cali-lean'. Also note how off-center the front wheels are--the PB arms should remedy most of this. I think I will wait until after I complete the trailing arm 'flip' before I plan any other drastic changes out back, as I'm pretty sure that mod will raise the rear an inch or so...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 09-09-2012 at 09:36 PM. |
#883 |
Truck looks really good. Should be fun to drive!
#884 |
![]() Join Date: Dec 2006
I love the way the rear looks, I would leave it like that and get the front down a little lower. What spring are you running in the front, maybe try a 3" lowering spring if your able too
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#885 |
You could just remove the 1.5" rear lowering blocks and see how you like it.
#886 |
Or just machine the blocks to the height you need to fine tune the rear drop and achieve the "right" rake you're looking for.
1968 SWB Stepside "Bella coming home" "Bella's Build Thread" A master in the art of living draws no sharp distinction between his work and his play. He simply pursues his vision of excellence through whatever he is doing, and leaves others to determine whether he is working or playing. To himself, he always appears to be doing both. L. P. Jack |
#887 |
I agree, bring the front down and your there.
#888 |
I like it! With a little fine tuning I have no doubt that you will get it where you want it.
BTW, I'm adding the sway bar to my '63 this week so I will give you some "feedback" on the handling improvements.
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
#889 |
He would still have to re-work the shock mounts as the blocks help w/shock travel. It will be interesting to see where the height winds up after the relocating of the front T/A pivot.
#890 | ||||||
A guy with a truck
![]() Quote:
Part of me agrees, but the other part doesn't wanna deal with all of the custom fab required to get there... Quote:
#891 |
Man of Mini-Talents
What's odd is that it looks like it's sitting level if you look at the top of the bed. Are your rims different diameters (too lazy to search)?
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
#892 |
A guy with a truck
20" wheels all around, but with a slight tire rake; 28" front/29" rear...
#893 |
A guy with a truck
Powder! Dropped off at lunch, picked up after work- how's that for service?!
#894 |
That's outstanding service! Looks like very high quality coating too.
#895 |
Hey Gringoloco,
Nice build, Quick question, I thought I had this figured out the last time I talked to Nate in regards to the 1" forward arms. After reading your thread is it only the requirement of lower control arms to benefit the 1" forward? What is the difference on the uppers they sent you vs the uppers for a standard dropmember. Thanks, Chapster
1967 GMC shorty Parts Pile: NoLimit, Accu Air, Kore 3, Matts Classic Bowtie, March Performance, Lokar, ScottsHot Rods, Vintage Air, American Auto Wire, Circle D, Accu Air, Borla, Budnik, Ididit, One Piece Windows, Doug Thorley, Pypes, AutoLoc, Porterbuilt, CPP, Dynamat, Dakota Digital, Fesler 1968 Chevy c10 shorty Stepper (Patina LS project) 1967 gmc custom Long Box (Farm Truck Project) |
#896 | ||
A guy with a truck
![]() My understanding is that there are forward uppers as well as standard uppers depending on what you're looking for. I was looking for cheap ![]() Posted via Mobile Device
#897 |
Powdercoat looks awesome, should have done that to mine but I cheaped out and painted them.
#898 | |
A guy with a truck
Here's a dirty-hack p-shop of what I would be happy with for ride height up front to match the current rear. I think I'd be pretty close to the stock inners at this height, but I love the look...
#899 |
I will be running lowers only, which will give more caster and less 'centering'. The upper arms were sent to me by accident, and are being returned
![]() My understanding is that there are forward uppers as well as standard uppers depending on what you're looking for. I was looking for cheap ![]() Posted via Mobile Device[/QUOTE] Thanks for the clarification. That is what I understood from Nate but thought maybe I was missing something. Cheers
#900 |
I'm just glad to be here!
Who did the powder coating? If you don't mind what did they. Charge for the control arms and brackets?
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
