Old 09-13-2012, 10:38 PM   #1
weider1717
2" and 2.5" lift options?
Doesn't look like tuff country offers a 2.5" kit. I am only going with 33's so a 2.5" is what I'm looking for. I hear such good reviews on the tuff country ez rides so thats what I want to go with question is will their 2" be enough not to rub with 33" on stocker 8" rallys even under mild offroading.
weider1717 is offline   Reply With Quote
Old 09-13-2012, 11:38 PM   #2
86454k30
86454k30's Avatar
Re: 2" and 2.5" lift options?
A 2" lift with 33's on 8" wheels is plenty. You won't have any problems. I have the same lift, tires and wheels on my blazer and with no problems....I don't have any pictures currently.
86454k30 is offline   Reply With Quote
Old 09-14-2012, 02:37 PM   #3
nobull2
nobull2's Avatar
please, if you get time put up a picture of your blazer with the 2 in lift and commit on the ride quailty.
thanks
nobull2 is offline   Reply With Quote
Old 09-14-2012, 03:56 PM   #4
JAA
JAA's Avatar
Yeah, I'd be really interested in seeing that too.
Jerry
JAA is offline   Reply With Quote
Old 09-14-2012, 04:36 PM   #5
86454k30
86454k30's Avatar
It will be a couple weeks before I can get a picture it isn't at my house. The ride is near stock with 2" tuff country front springs and hydraulic tuff country shocks.
Old 09-14-2012, 06:55 PM   #6
88Jimmy4x4
88Jimmy4x4's Avatar
here is my old Jimmy with tuff country 3" and 33x13.50 toyo MT on 15x8
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 09-14-2012, 09:44 PM   #7
JAA
JAA's Avatar
Man I really thought your Jimmy was taller than that. I thought for sure those were 35's.
Jerry
Old 09-14-2012, 11:14 PM   #8
weider1717
I remember when you lifted your jimmy....I remember reading you used th 3" tc lift but for some reason had to also had a 1.5" block to bring the rear up to match the front after the 3" tc springs were installed is that correct?
if so whats the deal with the 3" rear lift springs being 1.5" from the amount of life the front springs gave? that scared me from tc lifts kinda when i read that.
Old 09-15-2012, 11:12 PM   #9
Your41Plague12
Your41Plague12's Avatar
Pretty sure he used factory rear springs with a 1.5" block, not 3" rear lift springs too. It just helps to level it out, not lifting the rear as much. Nice ride, by the way!
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 09-16-2012, 02:18 PM   #10
88Jimmy4x4
88Jimmy4x4's Avatar
lol...stalkers
Actually I did install new leafs on all corners. However after I installed it the rear looked lower. After finding the leaf part number for rears it appeared they sent me 2" rear leafs with my 3" front leafs. Instead of me removing leafs, shipping back and getting new leafs I had them send me a 1.5" block kit to correct the height.
back to topic.....Not all tires are "true sized" meaning it may say 33x12.50 but not actually be 33" (my toyos were little over 33 and much wider). My advice is find the tire you want, look at the mfg actual specs first, then decide on wheel width and backspacing, then determine what size lift you need to not only clear them at the street driving but also be able to go offroad with them and clear the fender corners.
1991 GMC Jimmy 4x4
Old 10-13-2012, 04:41 PM   #11
weider1717
Could you post a pif with your 2" tuff country lift.
Old 10-21-2012, 10:21 PM   #12
byrdmann12000
i'm running Tuff Country ez ride 3" springs on my 86 K2500. clears the 33's with plenty of room,and the ride is not that bad.http://67-72chevytrucks.com/vboard/s...d.php?t=498338
byrdmann12000 is offline   Reply With Quote
Old 10-22-2012, 03:08 AM   #13
MTCK
MTCK's Avatar
I'm installing 2" TC springs right now. I'll post up pics as I go along with before and after measurements. Over in the 4x4 sectioin...
http://67-72chevytrucks.com/vboard/s...d.php?t=547921
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
