67 help with p/s and frame?
does anyone have pics on how to put the dimple in the frame for putting p/s on a 67? thanks Rick
Re: 67 help with p/s and frame?
Heres how I did mine.http://67-72chevytrucks.com/vboard/s...d.php?t=282720
Post 120 I have a pic http://67-72chevytrucks.com/vboard/s...=286089&page=5 I just heated with a torch and hit with a BFH. I had a power steering box to check fitment. It turned out ok, not happy with the hammer marks but you'll never see them when the box is installed.
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
looks like I get the BFH out and fire up the torches!
thanks guys |
You'll have to trim the front core support mount so that the PS box will line up with the existing holes. I just used a cut off wheel on a grinder for that. Also the bumper bracket will need trimmed to clear the box.
Further more some frame don't have the dimples where the bolt holes are located. I believe you can use a spacer to make up that difference. Nate
| Bookmarks |
