Old 10-15-2012, 04:09 PM   #76
factorystock
factorystock's Avatar
Re: Hubcaps
Check out these nos GMC caps. http://www.ebay.com/itm/1964-1965-GM...e654f4&vxp=mtr They are very nice, but be careful. These are not 3/4 ton 8 lug hubcaps like seller claims. They are not for 1/2 ton 6 lug with regular bump type wheels either.THey are for clip style 1/2 ton 6 lug rims, but agian watch out, must be a 6 lug clip rim with sharp drop off around lug center like the green rim in my post # 67, won't fit 40's to mid 50's wheels 6 lug rims with clips with the broad wide shallow drop off around lug center.
factorystock is offline   Reply With Quote
Old 10-15-2012, 04:57 PM   #77
1963c-10
1963c-10's Avatar
Re: Hubcaps
Ill post a pic of them for reference
1964 Short bed trailer
Old 10-17-2012, 04:33 PM   #78
1963c-10
1963c-10's Avatar
Re: Hubcaps
Good example of clip vs/non clip style cap. The two lower caps are for the clip style rim.
Old 10-17-2012, 04:44 PM   #79
1963c-10
1963c-10's Avatar
Re: Hubcaps
Here are a clip style steelie, a drum brake steelie (has 3 bumps on the front for hubcap), and a disc brake steelie (has 4 nubs on the front for hubcap)(also has different slots than the drum steelie). Pic is for reference to show that you can use a gen 2 c-10 rim w/OEM 61-66 caps. The disc steelie is perfect for the disc brake conversion and you want to retain factory hardware.
Old 10-20-2012, 03:03 PM   #80
rideblue00
rideblue00's Avatar
Re: Hubcaps
1963c-10, so your saying that you can use a 60's nub style hubcap on a late 60's/70's 4 nub 6 lug rim? Because i am looking to upgrade to disc in the future. But i want to use my 66 stock hubcaps.
rideblue00 is offline   Reply With Quote
Old 12-03-2012, 03:32 PM   #81
1963c-10
1963c-10's Avatar
Re: Hubcaps
Rideblue00....sorry took so long to respond. Just say the question. Yes, you can use the OEM dogdish caps on the newer 4 nub rims. The 4 nub rims are made for disk brakes.
Old 12-03-2012, 06:15 PM   #82
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Hubcaps
The reason the 3 nub hubcaps work on the 4 nub wheels is because on the 3 bump wheels, all 3 bumps are the same depth. On 4 bump wheels, 2 of the bumps are standard size (like on 3 bump wheels), and the other 2 are very shallow by comparison. So overall the hubcaps only need to stretch a small bit more to mount on a 4 bump wheel.
The difference in bump sizes can even be seen in the small disc brake wheel photo above. The north and south bumps are clearly visible. The east and west bumps are much smaller.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 12-03-2012, 07:49 PM   #83
1963c-10
1963c-10's Avatar
Re: Hubcaps
ill get a better close up pic of a 4 bump tonight. mine are setting in the parts room in fresh paint
Old 12-03-2012, 08:57 PM   #84
Auctioneerhere
Re: Hubcaps
I'll post a picture tomorrow of yet another option for hubcaps.
Auctioneerhere is offline   Reply With Quote
Old 12-04-2012, 09:33 AM   #85
1963c-10
1963c-10's Avatar
Re: Hubcaps
Here are some close-ups of the 4 bump rim. I rotated the pics to show the 2 larger bumps in a north to south reference and the two maller bumps in the east to west direction. Took a few different pics due to lighting.
Old 12-05-2012, 10:23 PM   #86
Auctioneerhere
Re: Hubcaps
Old 12-05-2012, 11:42 PM   #87
1963c-10
1963c-10's Avatar
Re: Hubcaps
im not very versed on the 48-55 era chevys,but those look like 50-53 time frame
Old 12-08-2012, 01:51 PM   #88
Andice
Andice's Avatar
Re: Hubcaps
How about this....
http://www.ebay.com/itm/63-64-65-66-...21034945477%26
Andice is offline   Reply With Quote
Old 12-08-2012, 11:41 PM   #89
1963c-10
1963c-10's Avatar
Re: Hubcaps
those are 64-66 factory 4wd hubcaps. very hard to find.
Old 12-08-2012, 11:58 PM   #90
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Hubcaps
Originally Posted by 60n60Apache View Post
Can someone tell me what these caps came off ?Attachment 967509
I just bought 4 for my 1964 Chevy from a place in Eugene, OR. The guy told me they were off a 66/67 Chevelle. I think they look just right on a 64/66 pickup.
TBONE1964 is offline   Reply With Quote
Old 12-09-2012, 12:32 AM   #91
yelmer
Re: Hubcaps
there is some factory 4x4 hubcaps on ebay 110986447820 item number said to be original
yelmer is offline   Reply With Quote
Old 12-09-2012, 04:57 PM   #92
1963c-10
1963c-10's Avatar
Re: Hubcaps
thats the 4x4 caps i was talking about
Old 12-09-2012, 06:58 PM   #93
Auctioneerhere
Re: Hubcaps
Those 4x4 hubcaps are now on my list to get cheap.
Bound to be a ton of those out here some place.
Old 12-10-2012, 12:18 AM   #94
HouldenCaulfield
Re: Hubcaps
I have a pair of NOS 64-66 hubcaps chevy hubcaps in great condition. I don't need them because I have the wrong style wheels for them and have decided to go another direction. I just put them on ebay.
HouldenCaulfield is offline   Reply With Quote
Old 12-10-2012, 12:30 AM   #95
60n60Apache
Re: Hubcaps
Hi TBONE1964,
They look great on the steallies, But I'm looking for the 57/60 for my 1960.
60n60Apache is offline   Reply With Quote
Old 01-01-2013, 08:12 PM   #96
factorystock
Re: Hubcaps
Probably off a 64-65 GMC 4X4, Chevy did not offer them during these years. Here is '62 GMC with rare chrome 4X4 caps.
Old 01-01-2013, 09:08 PM   #97
RANDY COX
RANDY COX's Avatar
Re: Hubcaps
WoW,I loved this thread,got to see and give me Ideas,PERRO13 what wheel and tire combo are you running on that Burb,Me Likes the looks.I too am wanting to go with a 16" wheel with caps,I have some 16"wheels 6-lug from my ole fleetline but not sure if they will clear the disk brakes on my 64 4x4 with early 70's running gear.as of right now it has a 3/4 ton runnning gear with 456's gears I'm wanting to go with 1/2 ton running gear with better gears for Hi-way.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 01-01-2013, 09:10 PM   #98
RANDY COX
RANDY COX's Avatar
Re: Hubcaps
Originally Posted by Auctioneerhere View Post
Auctioneerhere,those wheels are the same as my 48 fleetline,16" with clips for caps.....
1964 BBC 402 4x4
Old 01-01-2013, 09:33 PM   #99
burbluv
burbluv's Avatar
Re: Hubcaps
Does anyone know if Chevy made 62 chrome caps with the fronts punched out for 4X4?
I have always been told no but to see the 62 GMc gives me hope for my Chevy suburban.
Any insight would be great or if anyone can help me get a hand on some.
burbluv is offline   Reply With Quote
Old 01-01-2013, 09:56 PM   #100
RANDY COX
RANDY COX's Avatar
Re: Hubcaps
Is that color blue the dark blue from that era 60's truck..
1964 BBC 402 4x4
