Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 11-03-2012, 07:39 PM   #176
67shortie
Green club
67shortie's Avatar
Re: Let's see pics of paintjobs done yourself...
Here is a couple, BUT the HB gun is not exactly what I would suggest using for a decent finish, but it can lay clear down OK in the right conditions. In my defense I have a few cars I have painted under my belt, used quality material (chromabase Dupont) and got it to flow OK. In retrospect a nicer Devilbiss or a similar gun would be a worthwhile investment, and the final finish would have come out nicer.
I am in the middle of a complete on my son's 61 Continental and the HB gun is staying in the cabinet for this one. Primers maybe, topcoats no, the Devilbiss 'plus' is going to be my choice for the job but that is a $300 gun new its not cheap by any means.
Thank you for the props on the truck, lots of sweat went into it
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 11-03-2012, 10:43 PM   #177
kev2809
low n' slo
kev2809's Avatar
looks good from here...i only use mine for primer right now, i sprayed some single stage with it and it was real hard to tone it down. ill be getting a new gun for the basecoat.
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 11-10-2012, 06:19 PM   #178
shortbed70
shortbed70's Avatar
My candy painted firewall!!! Hok apple red candy over black!
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 11-11-2012, 08:05 AM   #179
tazattitude
tazattitude's Avatar
Looks great. Normally if you spray a candy over black, you don't see the candy. Sure that's not a black metallic or a charcoal metallic?
TAZ
BUILDS
1966 GMC Suburban
1963 GMC Suburban Patina frame-on FOR Sale
1966 C10 Short Bed (2010-11)
Monthly Updates
2015 C10 Pics with my '72 Montego GT 429/521 build
1963 Pro Street C10 back halved. Frame off I did back in 1990
Pics / Video
tazattitude is offline   Reply With Quote
Old 11-11-2012, 08:24 PM   #180
shortbed70
shortbed70's Avatar
Apperantly my phone turns pictures sideways for no reason... Fixed it!
Troy
Big Red Dog build
Old 11-11-2012, 08:29 PM   #181
shortbed70
shortbed70's Avatar
Yup 100% because the base is off a 98 mustang black as black can be. The actual uk11 (urethane kandy) has to be over a metallic or pearl base because there is no metallics or pearls in the midcoat on a tri coat paintjob. This hok paint uses a shimmering basecoat and adds stuff to it to make it close and its very close!!! I unwrapped it and started painting some of the accesories to match the motor but here it is unwrapped!
Troy
Big Red Dog build
Old 11-12-2012, 10:12 AM   #182
mrhino
5 long months, but I finally got mine painted
Sanded the the body, got it ready for some primer
1st coat of Epoxy primer
Sanded to find high and low spots, then filler work
Second coat of epoxy
A good coat of Polyester primer (feateherfil)
Block sanded
4th coat of epoxy primer
Block sanded again
Epoxy mixed up as a sealer coat
Base coat
Finally Clear!
All products were from Southern Polyurethane!
mrhino is offline   Reply With Quote
Old 11-12-2012, 10:44 AM   #183
PD1292
PD1292's Avatar
Mine is in the process now. My first paint job.
PD1292 is offline   Reply With Quote
Old 11-12-2012, 10:57 AM   #184
sduckworth13
sduckworth13's Avatar
Nice job PD1292, what color did you use?
Scott
sduckworth13 is offline   Reply With Quote
Old 11-12-2012, 11:14 AM   #185
PD1292
PD1292's Avatar
It is called Heritage Blue, its on the new 2013 GMC Z71 heritage edition. I think it is also an older color called blue topaz or lemanz blue, or zenon blue. It has been on I think the 04 chev pickups, on some corvettes and on cadi cts. I saw it on a dealer custom at a local car lot and got the paint code off of it.
and thanks sduckworth
Old 11-13-2012, 03:17 AM   #186
PAWS 72
PAWS 72's Avatar
Done this one back in 2001.Thought it was going to just get by and it has stayed on for 11 years now.Sherwin Williams brand. 2nd line.single stage.
PAWS 72 is offline   Reply With Quote
Old 11-13-2012, 03:21 AM   #187
PAWS 72
PAWS 72's Avatar
didn't list first time
Old 11-13-2012, 10:59 PM   #188
PD1292
PD1292's Avatar
Wow mrhino & paws those look great!
Old 11-14-2012, 09:26 AM   #189
mrhino
thank you
Old 11-18-2012, 09:30 PM   #190
Solo2002
Solo2002's Avatar
heres one from last spring
1966 C10 short stepper KMHK
Solo2002 is offline   Reply With Quote
Old 11-18-2012, 09:34 PM   #191
Solo2002
Solo2002's Avatar
one from this spring
Old 11-18-2012, 09:35 PM   #192
Solo2002
Solo2002's Avatar
and my 66 short step side im currently building
Old 11-27-2012, 01:11 PM   #193
srob67
My son and I have been working on her for 3 years. It's finally close to complete. PPG DBC 2000 Synergy Green. Sprayed with an Iwata 400. My son did all the body and paint work.
srob67 is offline   Reply With Quote
Old 11-29-2012, 07:09 PM   #194
thedirty1
This is my 99 s10. It was sprayed with all Dupont products. It started with 2590s epoxy primer then 4 coats of 7707s surfacer. After being blocked with 320 dry then 500 wet, it was shot with 1 coat of 7770s sealer, 3 coats of a custom mixed chromapremier basecoat, and cleared with 2 coats of 74700s chromapremier pro clear. The following day everything was wet sanded with 800 then 1000 and sprayed with 2 more coats of clear. I should have washed it before I took the pics
thedirty1 is offline   Reply With Quote
Old 11-30-2012, 12:21 AM   #195
Low Elco
Did all the metalwork, bodywork and cut-ins at the house shot in the booth at the shop my brother manages, cut and buff and assembled at home. Did it all right down to the color matched bedliner!
Name:  IMG_2742 (800x600).jpg
Name:  IMG_2747 (800x600).jpg
Name:  IMG_2792 (800x600).jpg
Name:  IMG_2896 (800x600).jpg
Name:  IMG_2902 (800x600).jpg
Low Elco is offline   Reply With Quote
Old 11-30-2012, 03:59 AM   #196
bk2life
too many to post, so http://www.ifitsgotwheels.com/pictures/
enjoy
bk2life is offline   Reply With Quote
Old 11-30-2012, 05:25 PM   #197
blfuller123
blfuller123's Avatar
Finally I can post here. My dad and I just finished up the suburban, was done in the garage.
blfuller123 is offline   Reply With Quote
Old 12-02-2012, 10:48 AM   #198
65truckowner
65truckowner's Avatar
Heres one I restored last year
65truckowner is offline   Reply With Quote
Old 12-02-2012, 12:30 PM   #199
gearys 5600
gearys 5600's Avatar
I love that color..I painted a Suzuki gsxr synergy green this summer.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629
1969 custom/10 swb--SOLD
1968 swb 50th anniv.--SOLD
1967 camaro ss/rs..LS-6-speed, 16-year long project
1956 chevy nomad
1955 chevy 210 2-dr sedan
1978 el-camino ss 1-owner
gearys 5600 is offline   Reply With Quote
Old 12-02-2012, 12:31 PM   #200
gearys 5600
NiCE suburban...
1956 chevy nomad
