Old 11-01-2012, 04:30 PM   #26
forestb
forestb's Avatar
Re: drop spindle selection
I had a set of 2.5 inch cpp spindles and they did not work with the stock rim but worked fine with a 15X8 after market rally wheel. When I switched over to the 2 inch drop modular spindle it rubbed against the balancing weights on the inside of my wheel but that was the spindle for the 77 c10 because I put a 77 cross member in my 62. I would just go with the 2.5 inch regular spindle if you front tires are 245s.
forestb is offline   Reply With Quote
Old 11-01-2012, 07:32 PM   #27
gimmy 64
i have 2 1/2 ece dropped spindles with 2 in. spring and 8 in corvette stye rallys and they don't rub
gimmy 64 is offline   Reply With Quote
Old 11-01-2012, 09:40 PM   #28
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Even if they do rub the wheel, it takes 5 minutes tops with an air sander to fix the interference. No reason to be scared of 2.5 spindles.
Tx Firefighter is offline   Reply With Quote
Old 11-01-2012, 11:09 PM   #29
TxRat
TxRat's Avatar
Call Justin @ Scotts Hot rods (805)485-0382. He's a forum member here and made me a smokin deal on my CPP dropped spindles from him in less than a week...
TxRat is offline   Reply With Quote
Old 11-01-2012, 11:42 PM   #30
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I think if I read in the first post, his a arms are powder coated which was why he did not want to grind on them.
Not sure when you bought your spindles but having been in the CPP machining room during their open house, their current spindles are not marked as Western and all of their finishing machining is done in house. They even have a very cool 3D plastic modeling equipment to make prototypes of parts before molds being made for casting. Very cool stuff.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 11-01-2012, 11:50 PM   #31
chevy_mike
chevy_mike's Avatar
Also, another thing that has come to light recently is the "old school" and "new school" spindles. The OS ones typically space out the wheel about 3/4" from the stock drums (some a little more) and can allow some stock steel 15x8 wheels clear because of moving the wheel out more BUT this can create issues with your tires rubbing the wheel lip depending on what size you run.
The NS style keeps the wheels spaced in correctly but it also moves the lip near the a arm and you're more likely going to have rubbing issues with 2.5" dropped ones versus 2" dropped ones.
There are a lot of ways things can turn out depending on wheels, tire size, spindle type, etc. There are just so many variables to be 100% sure. Good luck!
Old 11-02-2012, 04:45 PM   #32
Blue Heeler
Blue Heeler's Avatar
Thanks guys for all yer help!! just ordered them.
Blue Heeler is offline   Reply With Quote
Old 11-02-2012, 07:47 PM   #33
Clyde65
Clyde65's Avatar
Which ones?
I am being told I can't use the 2" modulars because of my 15"ralley and I'll need bigger brakes and wheels if I use them
But I got pricing for 2" drop spindles but they aren't modular, and both are CPP spindles,
However CPP only shows 2" modular and 2.5" traditional spindles.
What gives?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-02-2012, 08:11 PM   #34
Blue Heeler
Originally Posted by Clyde65 View Post
Which ones?
What gives?
The CPP 2 1/2 drop spindles.
Old 11-04-2012, 10:45 PM   #35
doobiebro
doobiebro's Avatar
Originally Posted by Calvin66c10 View Post
Somewhat irrelevant but what is the diameter on the hub of those 6 lug disc brakes? Looking to clear a rim with a 3" center hole. thanks
Sorry for the late response Calvin66... I went out to measure and its very close to 3".. You might have to grind very little if its too tight...
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 11-19-2012, 07:05 PM   #36
Bearcamp
This is the spindle I'm looking at from Summit. Can I use this spindle and use donor parts from a 73-87?
Bearcamp is offline   Reply With Quote
