WTB Dana 60 track bar frame mount
I'm getting ready to swap out my HO52 4.10's for a Dana 60 3.54's. In my reading up on this swap, it appears I need a different frame mount for the track bar.
'67 C20 LBW |
Re: WTB Dana 60 track bar frame mount
Did any of the coil spring trucks come with a DANA 60? I think you'll have to make a bracket to mount the track bar to the trailing arm/axle mount. If you have the Axle end mount, can you show a pic. I'm looking to swap my leafs for trailing arms and bags with a Dana 60. Mines a 3.54 also.
Check with Jeremiah King or Teeitup, anyone that parts out these trucks on a regular basis. The brackets are often left behind when rears and bars are removed since they're a bit of a pain to grind the frame rivets off. Just as the HO, D60 and 12 bolt panhard bars are all different, I seem to remember their respective frame mounting brackets being different as well. Most guys missing them just run an aftermarket adjustable bar, which comes with its own upper and lower mounting brackets.
12 bolt frame bracket just for reference; http://67-72chevytrucks.com/vboard/s...08&postcount=1 |
Vintage 4x4s
Yes, I have a 72 C20 coil spring pickup box trailer here with a D60 3:54 in it. The Dana offered the more freeway friendly ratio which a big block could get away with. Look for a C20 chevy BB truck if you want to find a D60 coil spring rear.
I also have a 67 C20 coil spring pickup box trailer here with a HO52 in it. I can compare brackets if nobody chimes in with the answer.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
#5 | |
'67 C20 LBW |
#6 | |
'67 C20 LBW |
I have a 72 big block truck with the coil spring dana, but it will be at least a month before I get to it.
Thanks Ray. It might be that long before I'm ready to do it. Swapping in a 700r4 at the same time, so I need to get all my ducks in a row. Keep me in mind when you do, I have a feeling I'm gonna have a hard time finding it.
'67 C20 LBW |
If someone can't come up with one sooner than I can do $25 shipped.
Thanks, Ray |
Sounds good. Like I said, It will be a bit, so please keep me in mind. I'll hit you up in a few weeks to touch base. Thanks a ton, Scott.
'67 C20 LBW |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
I installed a 3.54 Dana 60 possi in one of my old 67 chevys that originaly had a corperate 10 bolt. It was a 2 wheel drive and had the coil spring rear end. I had to use the pan hard bar from the Dana, but I used the original frame bracket on the 67. Didn't have any problems, it just bolted wright up. I of coarse had to have the rear driveshaft shortened and the whole driveline reballanced. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
#12 | |
'67 C20 LBW |
What's to be confused about? It should bolt wright up. It did for my 67 C/20. Driveline was my only modification that I had to make. Well and I had to use the panhard bar from the donor truck. (it was a 72 BB suburban) I also stuck the 67's rear end back in the suburban and used the 67s old pan hard bar. WES
Vintage 4x4s
700R4 and 3:54's? I hope you are not running large tires and that you have an engine with good torque numbers. You'll be ok with the low 1st gear but OD could be lugging the engine unless your unloaded. May tow at a pretty nice rpm though if you leave in 3rd. Curious what tire size and engine specs you have as I am contemplating using my 3:54 D60 for something other than trailer duty.
#15 | |
'67 C20 LBW |
#16 | |
Vintage 4x4s
#17 |
I'm running 2005 5.3 and 4l60e with my Dana 60, 3.54 gears. I tow a 1968 Airstream weighing 5000 lbs and a 700 lb motorcycle in the bed, no problems. 31 inch tall tires also. No lugging problems. I usually tow in overdrive except when hitting the hills. Run an auxilliary tranny cooler with the radiator cooler also. Can someone post pics when they have time of the Dana 60 with coils and the bar mounts at axle and frame. Hope I'm not jacking your thread ScottG, just trying to keep info in one place. Good luck. Jim
#18 | |
Dana 60 3/4 ton coil rear; panhard bar setup: http://67-72chevytrucks.com/vboard/a...1&d=1311728211 http://67-72chevytrucks.com/vboard/a...1&d=1320504408 http://67-72chevytrucks.com/vboard/a...1&d=1294027266 http://67-72chevytrucks.com/vboard/a...1&d=1294027266 http://67-72chevytrucks.com/vboard/a...5&d=1299336109 |
| Bookmarks |
| Tags |
| track |
