Old 08-23-2012, 02:27 PM   #1
19seventeeCustom
alternator wiring
Hey guys
I'm using the psi harness for my swap. The harness has 1 wire
going to the alt connector, I guess controlled by the PCM.
Do I just run a 12v power wire from the back of the alt to either
the pos+ starter lug or pos+ side of battery? and I'm done?
thanks
19seventeeCustom is offline   Reply With Quote
Old 08-23-2012, 08:06 PM   #2
clinebarger
Re: alternator wiring
Should work, Most LS1 F-bodies are wired that way.
clinebarger is offline   Reply With Quote
Old 08-23-2012, 10:27 PM   #3
19seventeeCustom
thanks clinebarger.
I'm running it to the starter. Just now putting the finishing touches on the swap. I'm ready to drive this thing already!!
Old 08-24-2012, 01:10 PM   #4
ls1nova71
ls1nova71's Avatar
I would use at least a 10 gauge wire for it too.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 08-24-2012, 01:14 PM   #5
19seventeeCustom
will do. I've got some 4g waitin to go on.
thanks for the help guys
Old 08-26-2012, 09:45 PM   #6
mooseknuckles
mooseknuckles's Avatar
I wired mine that way as well..also have a psi harness...
mooseknuckles is offline   Reply With Quote
Old 09-02-2012, 12:13 PM   #7
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
I too have the PSI harness. How did you all wire the power to the cab? The voltage regulator goes away and leaves a brown and red wire. The red wire is a branch off of the red wire that goes to the back of the Alt, so I figure I can delete it. But what do I do with the brown wire?
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 09-02-2012, 08:52 PM   #8
clinebarger
The brown wire is called the "Field" wire, It's no longer needed.
Old 09-02-2012, 09:37 PM   #9
C10_ustacould
Cool, thanks! I am too nervous about cutting out something I may need later!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 12-02-2012, 10:20 PM   #10
terrylgreenjr
I've got the psi harness too. It came with a 4 pire plug with only 1 wire in it. Is this the alternator plug? I have a alternator that has a 2 wire plug and a post for positive on the back Can I change the connector
terrylgreenjr is offline   Reply With Quote
Old 12-03-2012, 09:11 PM   #11
C10_ustacould
That is the alternator plug, it is for the factory LS alternator. I am not sure which alternator you have, but I am sure Jon at PSI will be happy to help you. Give him a shout, jvezzosi@psiconversion.com.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 12-07-2012, 10:23 PM   #12
terrylgreenjr
I found out I have a LS truck alternator I think one wire is for the exciter and one for the gauge. I got the plug from my factory harness and used 1 of the wires for the exciter Hopefully it will be running in the next week and Ill see if it charges
Old 04-18-2013, 11:48 PM   #13
cjohnson6772
cjohnson6772's Avatar
I just want to clarify before I make an assumption and then a mistake
You reused the original red wire going to the back of the alternator and then just removed all 4 branch wires going to the old regulator? The original wire the went to the back of the old alt. was basically a wore that ran back to the junction block on the passenger fender across the core support?
cjohnson6772 is offline   Reply With Quote
Old 04-19-2013, 12:08 AM   #14
C10_ustacould
Seems correct to me.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 04-19-2013, 12:10 AM   #15
cjohnson6772
Somehow that just seemed too easy........
Old 04-19-2013, 12:22 AM   #16
C10_ustacould
Yep, basically I ended up with the red wire coming off the alternator to the junction where the regulator was then splitting off with one side going to the firewall and the other going to the positive side of the battery (through the junction block on the fender).
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
