12-11-2012, 09:12 PM | #1 |
Black silicone removed?
previous owner siliconed whole windshield in...i have new windsheild and new gasket. How do i remove all that old crap off cab and window channel? Razor? Solvent? What works best.. thanks guys. By the way its an 82 short bed. Thanks
Posted via Mobile Device |
12-11-2012, 09:43 PM | #2 |
Re: Black silicone removed?
if you have a die grinder could use a soft wire wheel or wire brush to get most of it off then just hit it with some goof off and clean it real well then paint the area to prevent rust
12-12-2012, 09:19 AM | #3 |
Robert Olson Transport
better make sure you have a spare windshield first... when its silicone in removal is tough without cracking it up
razorblade on the glass to remove silicone if you get it out ok and then as described above for the metal side
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
12-12-2012, 10:08 AM | #4 |
Silicone will rust out metal.... I would try solvent before the grinder(goo be gone...thinnner)....unless you are going to paint it..
12-12-2012, 11:26 AM | #5 |
I would suggest trying an eraser wheel in a die grinder. I have used it on stripes so it might work on silicone. It won't hurt the paint.
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
12-12-2012, 12:35 PM | #6 |
buffle
My 87 was the same way , what I found after removing black goo was scary. There was rust everywhere in window channel. But actually removing the goo wasn`t too bad , after the initial cut it peeled out fairly easy.
Life is like a roll of toilet paper. The older it is, the faster it is used up. |
