Old 09-09-2012, 06:18 PM   #1
NW_Ryker
Hatch Handle Removal
I'm having some trouble getting the pin at the bottom of the shaft of the hatch handle on my Blazer. PB Blaster doesn't seem to be working. Here's the thing: the handle itself is actually broken off anyway so it's junk anyway. Knowing that, what would be my best course of action? I'd like to get this replaced. I'm getting awful tired of that thing banging every time I go over a bump.
NW_Ryker is offline   Reply With Quote
Old 09-09-2012, 08:17 PM   #2
pound41
Re: Hatch Handle Removal
I had the same problem. took a grinder and cut the shaft then replaced with garage door handle from home depot
pound41 is offline   Reply With Quote
Old 09-09-2012, 08:35 PM   #3
NW_Ryker
That's what I was thinking. Did you just cut it right where the pin goes through? Did it come out alright after that?
Old 09-12-2012, 09:41 PM   #4
72K5NTX
72K5NTX's Avatar
Yup like pound said, cut it off with a grinder (I used a hack saw) about where the pin is but save the whole cam mechinism if possible. Knock the square stock out of the cam and slide in a garage door handle (I got mine at Lowes, but China makes em all the same) then pin it on the other side of the split ring. Instafacto new handle! I know your pain mine came off and stayed off for two years because I was looking for a replacement handle. Not enough money or availability for that, I kick myself for not doing it sooner!
72K5NTX is offline   Reply With Quote
Old 12-23-2012, 10:51 PM   #5
PDXk5
PDXk5's Avatar
I searched for posts on hatch handle removal - great posts here on the forum have helped me get to this point but I can't seem to get the handle to slide out. I removed the cotter pin (well tried and it broke). The handle does not slide/move in and out, it seems to be stuck and moves in unison with everything.
Blazer Hatch Handle by Luftwaffepdx, on Flickr
I have disconnected the side bars, removed the angle retainer palte but can't get any farther. Any suggestions? I have sprayed it with CorrosionX but it doesn't seem to be doing anything. Do I need to give up and saw off. Will applying heat help ? - that might be tricky with the fiberglas.
I don't want to mess up the handle if I can help it. The chrome is in great shape - I just need to have it rekeyed and secure side bars so the handle is oriented horizontally rather than poping up on one side when reinstalled.
Thanks for your help.
PDXk5 is offline   Reply With Quote
Old 12-24-2012, 11:27 AM   #6
4oldcars
4oldcars's Avatar
I'm in the same place as PDXk5. Anyone know how to get this apart?
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
Old 12-24-2012, 11:34 AM   #7
Dale99
Same here. Once my used handle comes in, I'm likely just going to cut it in half.
Dale99 is offline   Reply With Quote
Old 12-24-2012, 01:03 PM   #8
jaros44sr
jaros44sr's Avatar
Well, use guys better figure it out soon, or i wiil be shipping alot of broken handle parts
HAPPY HOLIDAYS
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-24-2012, 08:44 PM   #9
pound41
I would suggest you cut it to get it out and then punch it through. If you were reusing. I got mine free with a c clamp at one end of the shaft and the other end hooked to the metal bracket and pressed it out.
