Old 01-06-2013, 03:12 PM   #1
LSUMurse
LSUMurse's Avatar
At the junkyard, have a question
Will this clutch fan fit in my '68?
Donor is a '81 C10 with a V8. I have a 307.
It's not that I am apathetic, I just don't care.
If your life is a joke, it appears death will be your punchline.
LSUMurse is offline   Reply With Quote
Old 01-06-2013, 03:27 PM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: At the junkyard, have a question
I believe the bolt pattern is the same
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 01-06-2013, 04:36 PM   #3
69GWC
So long its a 18" or 17" I believe.
69GWC is offline   Reply With Quote
Old 01-06-2013, 06:30 PM   #4
hugger6933
Your cleared for take off
hugger6933 is offline   Reply With Quote
Old 01-06-2013, 07:22 PM   #5
Andy4639
Old member
Andy4639's Avatar
Wink Re: At the junkyard, have a question
Get the fan pulleys and anything else they have for that setup. It will be fine.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-06-2013, 09:30 PM   #6
LSUMurse
LSUMurse's Avatar
Thanks for the quick responses and info. Once I got it off I could see where the fan had been rubbing against the shaft. So, I didn't take it, but I'll know for next time.
Thanks again,
-Stephen
