Old 01-06-2013, 08:50 PM   #26
Trsmotrhed
Trsmotrhed's Avatar
Re: 63 SWB C10 LT1/4L60E Swap
Installed my LMC tank kit and recessed the top of the tank to clear lines for the Tanks Inc PA series pump. The pump needs 1 1/4" clearance from the top of tank. I only had about a 1/2". I cut out the top of the tank, made a recess plate and welded it back in. Checked for leaks and none. Was happy. Used my mig welder with 023 wire. I'm looking at Tig Machines and may get one next month.
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline   Reply With Quote
Old 01-17-2013, 02:40 AM   #27
Trsmotrhed
Trsmotrhed's Avatar
Smile Re: 63 SWB C10 LT1/4L60E Swap
Started the LT1 today and ran great. Had to replace the TPS. Here's a video on you tube. I hope I did the link right.
https://www.youtube.com/watch?v=SVNX...e_gdata_player
63 SWB C10
Old 01-19-2013, 02:44 AM   #28
Trsmotrhed
Trsmotrhed's Avatar
Picture of engine. Downloading from mobile phone, hope it works.
63 SWB C10
Last edited by Trsmotrhed; 01-19-2013 at 02:45 AM. Reason: trying to upload pic from phone thru photo bucket.
Old 01-19-2013, 03:42 AM   #29
jimmydean
jimmydean's Avatar
Nice work.
If I buy back my totalled Vette I will be doing the same combo.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 01-20-2013, 12:13 PM   #30
Trsmotrhed
Trsmotrhed's Avatar
Still having problems uploading pics from phone. Was told use photo bucket, copy the img link and upload when posting. I'll post from computer later I guess. Anyone know how to post from mobile phone? Thanks
63 SWB C10
Old 01-26-2013, 09:05 PM   #31
Trsmotrhed
Trsmotrhed's Avatar
Here's a picture of the finished fuel tank with the tanks inc pa pump recessed in tank. Also a pic of the engine running. I need to finish up a few details and start on the 9" rear end transplant with disks and posi from a lincoln.
63 SWB C10
Old 02-17-2013, 12:03 AM   #32
Trsmotrhed
Trsmotrhed's Avatar
Got my new 4" rear Drop coils from CPP today.
63 SWB C10
Old 02-17-2013, 12:06 AM   #33
Trsmotrhed
Trsmotrhed's Avatar
Trial fitted my Silverado seats today.
63 SWB C10
Old 02-17-2013, 12:07 AM   #34
Trsmotrhed
Trsmotrhed's Avatar
Ordered 2.5" dropped spindles, lowering springs from CPP.
63 SWB C10
Old 02-17-2013, 01:18 AM   #35
1enick72
1enick72's Avatar
Looking good. I have done the same swap in my truck. I have an external fuel pump with a return line run into the original sending unit but the pump is noisy so it's time to go with a rear tank set up.
65 short step
edited by staff
1enick72 is offline   Reply With Quote
Old 02-17-2013, 12:16 PM   #36
Trsmotrhed
Trsmotrhed's Avatar
The in tank pump is the only way to go. I had an external pump on my last truck and drove me nuts. I don't hear this one at all. Only when you first turn the key on. I used the Tanks Inc PA series. I got the I believe 4 series Incase I want to go with and LS engine latter, this pump with supply the extra pressure. Its only $10 more.
63 SWB C10
Old 02-27-2013, 11:26 AM   #37
88Lt1wagon
Looking clean, I've still got wires all over the place in my wagon and I've been driving it daily for almost a year...
-Jason
'66 C10 LWB 2 BBL 283 w/ T-5
'90 V1500 Suburban TBI 350 w/ 700R4
88Lt1wagon is offline   Reply With Quote
Old 02-27-2013, 07:20 PM   #38
Trsmotrhed
Trsmotrhed's Avatar
It's kinda fun driving them. I have the bed off mine and get the weirdest looks when driving. I love how my truck runs. Thank for looking and your comments. I'll look at yours.
63 SWB C10
Old 02-27-2013, 07:41 PM   #39
88Lt1wagon
I haven't done anything of note to the '66 yet, but here's a little documentation on my LT1
http://youtu.be/2WKq61_O49w
I'm not sure what I want to do with my C10, a 350 that looks like a 283, or an LS based motor. It almost got my LT1, but when my wagon's 307's head gasket started leaking, that was that.
-Jason
Old 02-27-2013, 08:23 PM   #40
Trsmotrhed
Trsmotrhed's Avatar
Looks good. Can't beat fuel injection. I think the LS based motor would be nice.
63 SWB C10
Old 02-28-2013, 10:07 PM   #41
Trsmotrhed
Trsmotrhed's Avatar
Installed the 4" rear drop coils. Need to install the front lowering components now.
63 SWB C10
Old 03-03-2013, 12:02 AM   #42
Trsmotrhed
Trsmotrhed's Avatar
Installed the passenger side CPP 2.5" drop spindle with a 1" drop coil.
63 SWB C10
Old 03-03-2013, 08:24 PM   #43
Trsmotrhed
Trsmotrhed's Avatar
Just finished installing the 2.5" CPP drop spindles with 1" drop springs. Upgraded the disks to slotted rotors and powder coated calipers. Very pleased with how it handles. Next weekend rear sway bar, shocks and new trac bar.
63 SWB C10
Old 03-29-2013, 09:09 PM   #44
Trsmotrhed
Trsmotrhed's Avatar
I've been horrible about keeping up with pics. Here's some of the rear end.
This one is the trac bar bracket I built.
This one is with trac bar bracket installed.
Rear sway bar.
63 SWB C10
Old 03-29-2013, 10:12 PM   #45
Trsmotrhed
Trsmotrhed's Avatar
Worked on the bed today. Was able to save the bed side. The tail light panel needed replaced. Was able to cut it and only replace the bottom.
Tail panel welded in and side straightened out.
63 SWB C10
Old 03-29-2013, 10:43 PM   #46
Bomp
Bomp's Avatar
Nice clean job.
Bomp is offline   Reply With Quote
Old 03-30-2013, 12:03 AM   #47
Trsmotrhed
Trsmotrhed's Avatar
Originally Posted by Bomp View Post
Nice clean job.
Thanks, the other side is pretty bad and will need more work. Probably end up replacing the bed side and the tail light panel for sure.
63 SWB C10
Old 04-04-2013, 11:32 PM   #48
Trsmotrhed
Trsmotrhed's Avatar
Finished the gauge install finally.
63 SWB C10
Old 04-05-2013, 02:26 AM   #49
azdude1964
azdude1964's Avatar
looking good keep it comin.
efi 496bbc th350 custom brakes narrowed 9 coilover rear.
azdude1964 is offline   Reply With Quote
Old 04-05-2013, 09:16 AM   #50
Trsmotrhed
Trsmotrhed's Avatar
Thanks, maybe some day mine will look almost as nice as yours. That will be tough to get to the caliber of yours.
63 SWB C10
