C10 CLUB Y QUE!
Re: Porter Rack n Pinion Steering
can we use any GM power steering pump or do we need a certain pump?
You can use any chevy pump. One thing to keep in mind is that the pressure rating of the chevy pump is higher than the pressure rating of the Ford rack. You may decide to use a pressure regulator to tune in the "feel".
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
Registered Cruiser
Not trying to high jack....
But what about guys running an LS series motor? Can we use the newer factory hoses if using the truck accessory brackets?
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
You can use the newer pump with our hose kit. You might be able to have new ends crimped on the factory hoses to save a little cash.
Registered Cruiser
Thanks Nate! I will hit you up for the hose kit!
