Old 01-10-2013, 09:55 PM   #226
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Jim Bob a build thread
sure is easy to "plug and play"
found this critter living on it at the trailer
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 01-10-2013, 10:09 PM   #227
motornut
78K & 79C Jimmys
motornut's Avatar
used it more up there this year
seen this yellow one for sale...
John
Old 01-10-2013, 10:21 PM   #228
motornut
78K & 79C Jimmys
motornut's Avatar
well after the world ended(dec 21)
the only beast able to move was the 78
sure not the GA
no shoveling just back straight out
to bad the wipers broke as soon as i used them
John
Old 02-01-2013, 05:28 PM   #229
motornut
78K & 79C Jimmys
motornut's Avatar
last week -40
this wednesday +11 a record
thought a good day to replace the 78s dizzy...
gona miss that miss lol
John
Old 02-01-2013, 05:37 PM   #230
Telecasterjoey
Ha ha I've stopped and looked at that yellow truck too!
Telecasterjoey is offline   Reply With Quote
Old 02-01-2013, 07:15 PM   #231
kikkegek
kikkegek's Avatar
what kind of dizzy did you replace it with?
kikkegek is offline   Reply With Quote
Old 02-01-2013, 10:26 PM   #232
motornut
78K & 79C Jimmys
motornut's Avatar
lol I stopped to wait for the wife,she shook her head and kept drivin
i duno,I was talking with my parts guy wanting to get a new carb and dizzy.
he said he had ordered one ,and the guy changed his mind
he said 100 cash,I said yes
it was outa the box and in before dinner!
returned core already,i gotta stop in there in the morning I'll see if the core/box is still there
John
Old 02-01-2013, 10:44 PM   #233
mooseknuckles
mooseknuckles's Avatar
where was that?
mooseknuckles is offline   Reply With Quote
Old 02-01-2013, 11:52 PM   #234
motornut
78K & 79C Jimmys
motornut's Avatar
Originally Posted by mooseknuckles View Post
where was that?
end of ferry road@ the ranch
looking to see if i got some of the others there
John
Old 02-02-2013, 12:31 AM   #235
motornut
78K & 79C Jimmys
motornut's Avatar
seen these ones there for years,but they move
John
Old 02-02-2013, 12:46 AM   #236
motornut
78K & 79C Jimmys
motornut's Avatar
I'd cleaned it a few times,last time it seemed iced up rust lol
John
Old 02-02-2013, 12:54 AM   #237
motornut
78K & 79C Jimmys
motornut's Avatar
gona have to drive out and run the 79s
and i got weight springs in the glove box,to play with!
John
Old 02-02-2013, 01:06 AM   #238
motornut
78K & 79C Jimmys
motornut's Avatar
I want to make the burb center seat into the jimmy
at this point it dosn't fit between the seats
strip it down,build it up
I'm thinkin kinda hummer style,tall, black,subs,textured finish,cupholders,storage,....
John
Old 03-24-2013, 04:06 AM   #239
RoughKuntry
RoughKuntry's Avatar
Re: looking at a 78 jimmy
I am having problems with my gauges for my 79 High Sierra Jimmy, The lights have all been replaced yet they keep going out, Not to mention she is starting to make a few whining noises when I turn?
RoughKuntry
73 GMC 25 HUNDRED :Sold
79 GMC High Sierra 4x4 (Ma-Duece) :Sold
99 Chevrolet LS 4.8l/5 Speed Manual 4x4 :Selling
88 Chevrolet Burban 2500 4x4 :Buying
RoughKuntry is offline   Reply With Quote
Old 03-24-2013, 08:45 AM   #240
motornut
78K & 79C Jimmys
motornut's Avatar
Hi
I've found the best is to have it out,and apart
1.check all copper paths are straight,use crazy glue ,if any are loose
2.remove and check each bulb (meter it) make the contacts go down and under
3.i give each socket contact,a rub with very fine sandpaper
4.confirm the socket hole is clean,i'll use my finger,thumb to pry/bring up the socket contact to the board that turns in the hole,feel the little lock bump on each hole
5.even tho i might have seen the bulb looks good i test each one after socket inserted too
6.confirm with meter each path is good,you use one (you know is good) bulb ,move it around
7.I also bend to retension the gauge clips ,and then sandpaper to clean contacts
8.with the cluster out,meter the grey(is +),black is neg,turn the dial,meter should swing smooth,if it drops,the dimmer part of the headlight switch is burnt,replace the headlight switch
9.one of the the best things to do is to paint the housing white while totally apart,
I used what i had,
gloss white rust spray,
dosn't take much,but the end result it worth the time
hope it helps,let me know
John
Old 03-24-2013, 08:48 AM   #241
motornut
78K & 79C Jimmys
motornut's Avatar
wineing mght be a loose steering belt
or low fluid,some say use the tranny fluid,don't
headers or manifolds
some people forget to replace this brace
John
Old 03-24-2013, 09:04 AM   #242
motornut
78K & 79C Jimmys
motornut's Avatar
some things to check for
i also clean up the plug copper too,lifting up the contacts to retension those as well
John
Old 03-24-2013, 09:24 AM   #243
motornut
78K & 79C Jimmys
motornut's Avatar
that things huge!
John
Old 04-27-2013, 07:01 AM   #244
motornut
78K & 79C Jimmys
motornut's Avatar
cleaned up some bush for my Dad
John
Old 04-28-2013, 09:49 AM   #245
motornut
78K & 79C Jimmys
motornut's Avatar
second load we covered at home till i dropped it off sat 8:15 am
lol seems only the GMs started early this morning
John
Old 04-30-2013, 03:16 PM   #246
RoughKuntry
John, still having problems with the Jimmy, anyways I have some aftermarket parts for the gauges and I need a few pictures from you showing how to install the lighter, because when I tried it, it took away the dome light and horn, :/ I am a little frustrated at the moment so can I get a shout out please?
RoughKuntry
Old 04-30-2013, 08:49 PM   #247
motornut
78K & 79C Jimmys
motornut's Avatar
it could be the actual lighter part you push in ,not all are the same
how did you get power?
could be an orange right there....
black to ground?
John
Old 05-01-2013, 07:12 PM   #248
RoughKuntry
Another problem I am having with the rig is, I bought a aftermarket Holly Distributor, with a coil pack, yet I am having problems trying to find the Coil pack to the Flame Thrower Distributor that is on there now?
RoughKuntry
Old 05-02-2013, 08:34 AM   #249
motornut
78K & 79C Jimmys
motornut's Avatar
do you order from Summit?
http://www.summitracing.com/search/p...ignition-coils
John
Old 05-10-2013, 06:54 AM   #250
motornut
78K & 79C Jimmys
motornut's Avatar
did another load
got the stump out
I'm done and these guys roll up at the neighbours
John
