Old 01-15-2013, 04:56 PM   #1076
jmedero
jmedero's Avatar
Re: 1971 c10 stepside
You get the correct 4 link bars yet? Lets see this bad boy as a roller!!
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 01-15-2013, 05:36 PM   #1077
big_al_71
big_al_71's Avatar
The second set of bars showed up ans they were the same ones he received the first time. He shipped all four back already called left messages and is waiting for a call back since yesterday. I was at Raul's house Saturday..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 01-15-2013, 07:21 PM   #1078
Grip
Grip's Avatar
Originally Posted by raull
i could be wrong but something does not seem right to me , i installed the 4 bar link brakets where the instructions show , then the cnothc well opening centerline its suppossed to be 25.25 inches from the second bed mount hole , here's some pix , any thoughts, measurements or pix any body can share , thanks
My suggestion would be to take picture of how you measured the location of the notch. I hope this helps!
Grip is offline   Reply With Quote
Old 01-16-2013, 12:45 PM   #1079
higXtech
higXtech's Avatar
Will this project have AC?
1968 fleetside - nolimit wide ride front and rear + ridetech
higXtech is offline   Reply With Quote
Old 01-16-2013, 02:50 PM   #1080
PBFAB.COM
PBFAB.COM's Avatar
That sucks. No message on the voicemail from Raul... but we will give him a call back today.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 01-16-2013, 03:16 PM   #1081
PBFAB.COM
PBFAB.COM's Avatar
Raul-
The closer I look at this picture it appears that you might have the front bracket located too far forward. It's a possibility that the hole we referenced in our instructions is in a different location on your chassis. I will know for sure when the bars you sent back show up, and I can confirm the length. We can also get another measurement on that front four link bracket to compare its placement.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-16-2013, 03:49 PM   #1082
PBFAB.COM
PBFAB.COM's Avatar
Raul-
I went and took a couple other measurements for reference on that front bracket. My thinking is that if the front bracket is NOT in the right location we can just make a set of bars that will fit so that there will not be the need to relocate/redrill a bunch more holes.
We made the front four link bracket so it fit the leaf spring chassis, they actually bolt into place of the front spring hanger on the leaf spring frames. If we measure back 6" from the rearmost rivet on the front bed mounting bracket (see pics for reference) it will put us in the correct fore-aft location for the front upper mounting bolt on the four-link bracket. Take a look at these pics and we can determine if it's too far forward or in the intended location.
Again, I apologize for the inconvenience on the parts.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-16-2013, 05:34 PM   #1083
big_al_71
big_al_71's Avatar
video of raul's camaro
Old 01-16-2013, 10:33 PM   #1084
raull
raull's Avatar
will do in a few , thanks !!!
yes it will have ac !!!!
check out my build thread
71 c/10 step side 5.3 twin turbo
http://67-72chevytrucks.com/vboard/s...d.php?t=485320
raul
raull is offline   Reply With Quote
Old 01-16-2013, 10:38 PM   #1085
raull
raull's Avatar
ok here we go , in the instructions it says for the step side to measure 25.25from behind the hole of the second bed mount to the center of the wheel line so here the pix
raul
Old 01-16-2013, 10:41 PM   #1086
raull
raull's Avatar
now as for the four link bracket i went ahead and retaiped andstarted from the begining again i i did as the instructions said
raul
Old 01-16-2013, 10:45 PM   #1087
raull
raull's Avatar
so i went ahead and i measure from the center of the bolt to the center line i i cameup with 26 inches
raul
Old 01-16-2013, 10:50 PM   #1088
higXtech
higXtech's Avatar
Awesome. I can't wait to see how you do the intercooler/wastegate/intake piping.
Old 01-16-2013, 10:52 PM   #1089
raull
raull's Avatar
now if you take the 3 1/2 inches fron the center of axle to about half thred on the joint as i show in the picture that would mean that i need a 22.5 bar like it was marked on the bars i got exept the actually measure 20 in , now i dont think i need to move the brackets 2 1/2 inches forward if i do so be it let me know Nate , thanks ,
raul
Old 01-17-2013, 11:19 AM   #1090
PBFAB.COM
PBFAB.COM's Avatar
Thanks Raul. As soon as the bars show up I will see where we went wrong. From your pics and measurements shown, it doesn't appear to be off.
What do you get on this measurement?
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-17-2013, 11:57 AM   #1091
raull
raull's Avatar
ill check that later when i get home !!!! thanks
raul
Old 01-17-2013, 12:29 PM   #1092
lolife99
67-72 parts collector,…
lolife99's Avatar
Raull,... have you had your bed back on yet?
I would throw it back on and put a wheel in the center of the stepside fender's wheel opening.
To me,... this is the only way you will correctly position the rearend and the notch.
Then you can adjust/verify the bar length or front mount accordingly.
(ask me how I know. Ha)
Keith
Convert to disc brakes.
Old 01-17-2013, 02:39 PM   #1093
raull
raull's Avatar
it crossed my mind , i guess that would be a good thing to do , thanks
raul
Old 01-17-2013, 02:44 PM   #1094
PBFAB.COM
PBFAB.COM's Avatar
Keith is the original reason that we now have different dimensions and bar lengths for the rear components on a step side bed vs. a fleet.
He purchased a chassis for his stepper that had a Dropmember Rear installed that was fit up under a fleetside bed. Up to that point we had never heard feedback from anybody running a step side bed, and we had never installed one here at the shop under a stepper either. Needless to say we were all confused and surpsised by the fact that the rear wheel centerline was 1.5" rearward in the stepper fenders.
Anyways.... on our fleetside bars the center to center of the bushings is 23.5 inches. So we build the step side bars 1.25" shorter... making them 22.25. We also adjust the for-aft reference for notch placement.
Here's what I found when I measured your bars this morning (and I believe that some of the confusion was in our communication regarding what the 22.25" measurement should have been). They measure right at 22.25" center to center on the bushings.
Another observation is the height of your notch. It is hard to tell, but it appears that you have not trimmed it down any to set the height? The weld in notches come oversized, so depending on your tire height they might need to be trimmed down quite a bit. The taller the notch, the more the axle will swing forward until it bottoms out.
Also, it appears that the reference line you used to place the front bracket is not perpindicular to the ground. This could place the mount a little too farther forward as well. Might be a combination of a couple things compounding the issue.
Also, PLEASE do not take my communications as anything other trying to help you get it figured out and set up as it is intended. All I want is to make sure the kit goes in and functions as intended. I am definitely not trying to fixate any blame anywhere. Just want to help get it where it needs to be.
Just confirm or deny the 6" measurement for us and also the notch height and will get it all figured out.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-17-2013, 04:21 PM   #1095
raull
raull's Avatar
it all souds good , please send me back those same bars and i will take it from there , than you !!!!
raul
Old 01-17-2013, 07:01 PM   #1096
lolife99
lolife99's Avatar
Raull,... here is my before and after pics.
First one is standard PB "fleetside" 4-link chassis with the stepside bed.
Second pic is after I moved the notch forward and had Nate shortened the link bars.
My notch is too huge for a stepside bed.
These second pic tires are 29" tall and I can't lay out before the stepside fenders are setting on the tires.
This is also ride height!
Keith
Old 01-17-2013, 09:51 PM   #1097
raull
raull's Avatar
thanks for the info and pix , im picking up my bed and starting all over , after all i may even have the wrong offset wheels to go even lower than it was with the ridetech
raul
Old 01-18-2013, 11:02 AM   #1098
PBFAB.COM
PBFAB.COM's Avatar
Let's do this...
Get the bed in place.
Confirm the wheel centerline measurements and make sure the notch is centered.
Make sure the notch depth is correct so that when the axle is bottomed out it sits right where you want it (this is very important due to the way the bag is set up. If you have excess room in the notch when deflated, the bag will not get the total amount of travel).
Bottom the axle out in the notch then get me a center to center measurement on the bushing centers for the four-link bars. I will make you a set to that dimension. That way you don't have to re-locate the front mounting bracket. This will eliminate any additional holes in the frame.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-18-2013, 11:13 AM   #1099
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
I like that this is happening! Hopefully the stepsides with trailing arms will get fixed up next! I know the wheel offset in the stepside opening problem is not caused by any PB product, I am just hopeful Nate and his crew can give us a solution.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 01-18-2013, 09:31 PM   #1100
PBFAB.COM
PBFAB.COM's Avatar
We have it covered in the extreme version that lays frame.... Just don't have a stepside specific stage 2 kit yet.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
