Closed Thread
Old 01-19-2013, 01:40 PM   #5801
VWNate1
VWNate1's Avatar
Thumbs up Re : What did you do to your truck today!
You guys get so much done , it's inspiring .
I got the choke spring Flea-Bay links , thanx .
My truck as always , runs O.K. for an old beat up piece of junk , I need to dip into the engine & swap out the cylinder head for the rebuilt one I have , maybe replace the piston rings , the pistons too if they're not good , replace the bad exhaust manifold , get & install a new choke thermostat , replace the failing aftermarket radio etc. , etc.
Thing is I not only work slowly , I have serious physical limitations and , other vehicles are dead in the water so for now I just keep it full of oil and drive it....
The help and inspiration I get here , is priceless .
Don , remember to ensure the ATF filler tube hole is Hospital clean and free of any overspray , don't use regular O-Ring , viton or other hydraulic fluid resistant is necessary else it'll soon begin to weep & wet the tranny.
The yellow looks very nice indeed .
I see you bought a High Torque starter , that's wise .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 01-19-2013, 01:40 PM   #5802
jc70chevy
jc70chevy's Avatar
Re: What did you do to your truck today!
went and picked up some 030 wire and some new tips. now time to finish welding in the bed steaks
jc70chevy is offline
Old 01-19-2013, 02:46 PM   #5803
brian.kannady
put the fuel tank and seat back in it, changed the oil, and started it for the first time in 4 years. Ran great. Stopped very badly (is it bad when you have trouble stopping going up a hill at barely above idle speed?). Ordered brake parts.
brian.kannady is offline
Old 01-19-2013, 05:39 PM   #5804
Kevjulian
Kevjulian's Avatar
I installed new seat belts in my 71C20 due to one of the latches falling apart in my hands the other day
Kevjulian is offline
Old 01-19-2013, 10:33 PM   #5805
midniteblues
midniteblues's Avatar
I guess you could say "trucks"
you know after a swap meet or car show you allways get the itch too do something
test fitted the bb an t400 I really just wanted too see if my 69 camaro headers would fit..... so far I think they fit great......but I wanna use a manual trans
also helped an guided the kid on getting his timing chain replaced. its a lil' sloppy but I've seen worse.
at least no nylon teeth were missing.theres a cloyes double roller going in its place.I wish it would stay as nice as it was today that would make it go a lil' better since its being done outside
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline
Old 01-19-2013, 10:34 PM   #5806
ole dollor
ole dollor's Avatar
Nate glad you got the choke ordered, i really did not need to change my starter i had to , the old one bolted to the bell housing and with the auto trans it has to bolt to the motor, so that's why i got it...my son should be here Monday morning and we will start the auto trans project....i painted before i put the new seals in so i hope everything stays dry.....
ole dollor is offline
Old 01-19-2013, 10:54 PM   #5807
midniteblues
sounds like you got a job coming up getting then rivits out
Old 01-19-2013, 11:35 PM   #5808
ole dollor
ole dollor's Avatar
you are one up on me...not sure what you are talking about ....getting the rivits out?
Old 01-20-2013, 05:48 AM   #5809
Expat_dude
Expat_dude's Avatar
Rear Baer calipers are on
1970 Chevy swb, project UGHH!
1987 Grand National
http://s168.photobucket.com/albums/u.../1970%20Chevy/
Expat_dude is offline
Old 01-20-2013, 01:19 PM   #5810
oneoff
oneoff's Avatar
Ordered and received the power plant that will be going into my latest build....
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=541803
Dennis H
1969 Chevy C10, SWB, LS3,6.2L engine
1969 Chevy Chevelle SS,BBC, Convertible
oneoff is offline
Old 01-20-2013, 06:37 PM   #5811
jjhare
jjhare's Avatar
Finally got my rallies referbed..
Before and After.
1972 C10 CST LWB
jjhare is offline
Old 01-20-2013, 06:42 PM   #5812
c10monkey
c10monkey's Avatar
Before and After.
Looks Great!!!!!
Is that paint or powder coat?
How much?
1971 Chevrolet C10 Inflation Fighter
1994 C3500 Crew Cab Dually 454
c10monkey is offline
Old 01-20-2013, 06:48 PM   #5813
jjhare
jjhare's Avatar
Originally Posted by c10monkey View Post
Looks Great!!!!!
How much?
Rustoleum High Performance Wheel Paint (5 bucks a can), 4 coats over 3 coats of primer. Just sanded down good and cleaned them with por15 marine clean.
1972 C10 CST LWB
jjhare is offline
Old 01-20-2013, 06:49 PM   #5814
midniteblues
If your are replaceing a manual trans with a automatic you gotta get the manual trans crossmember out of the way and its rivited too the frame hence "getting the rivits out"
of course some people just cut the crossmember out. thats not fun either
Old 01-20-2013, 07:14 PM   #5815
ole dollor
ole dollor's Avatar
after bed time last night i figured out what you were telling me...lol, you know how us old folks are, yes i am just about down to that now, got every thing unbolted , may just leave that for monday when my son comes to help me...i have a real good air chisel and grinder....
Old 01-20-2013, 07:35 PM   #5816
myyamr7
myyamr7's Avatar
I put an HEI in my 71 Cheyenne today, what a difference!
myyamr7 is offline
Old 01-20-2013, 08:10 PM   #5817
Trsmotrhed
Trsmotrhed's Avatar
Attachment 1044699
What LS is that? You making your own stand alone harness for the spark and timing? Auto or ? Looks awesome and will be fun. I did the fuel injection and love it. Got tired of messing with carbs.
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline
Old 01-20-2013, 08:21 PM   #5818
1972SUPERSB
1972SUPERSB's Avatar
I may be doing this soon. What type of difference did you notice? Did you pull old one out and Stab new one in with rotor pointing same way to match old one? Thanks
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline
Old 01-20-2013, 09:34 PM   #5819
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today!
Replaced the old oil pressure senor. This one keeps the motor running as long as there is 5lbs of oil pressure to it.
It was leaking so I took it out. Have no idea why it was leaking though.
Here is the new one.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 01-20-2013, 09:50 PM   #5820
1972SUPERSB
Installed a vacuum gauge and painted door strikers
Jeff
Old 01-20-2013, 10:25 PM   #5821
myyamr7
myyamr7's Avatar
Cold start up is the first thing I noticed, it used to crank over for 5 or 6 seconds before starting when cold, now it just fires up. It also runs a lot smoother and seems to accept the throttle smoother as well. I have not run it enough yet to check fuel economy.
I checked the timing location with a light first, I couldn't find the timing specs on the truck anywhere, so figured it'd be close enough.
Yes, all i did was pull the cap off the old distributer, took note where the rotor was pointing, and dropped the new one in at the same location. Once it was running, I just set the timing light up again and used the same number the old one was set at, +7 at idle.
myyamr7 is offline
Old 01-21-2013, 12:13 AM   #5822
1972SUPERSB
Cool thanks for the info!
Jeff
Old 01-21-2013, 01:01 AM   #5823
Sklptrljay
Sklptrljay's Avatar
Cursed the Gol Danged 49ers (GO RAVENS!!!!) and removed my inner fenders and heater to make room for Vitage Air.
Sklptrljay is offline
Old 01-21-2013, 10:50 AM   #5824
VWNate1
VWNate1's Avatar
Post Re : What did you do to your truck today!
My 60's tranny cross member is bolted ~ I guess the DPO changed it , I'm glad he had the hard job instead of me ! .
HEI , or at the very least a Pertronix Ignitor breaker points is the smart thing for ALL older engines , you simply cannot imagine the improvement until you try it .
I hope Myyamr7 remembered to open the spark plugs up to at least .045" .
Even breaker point ignitions need .035" .
Oops ~ 'puter says re boot time .
-Nate
Geezer
VWNate1 is offline
Old 01-21-2013, 12:45 PM   #5825
Dnrice
Sanded and primed front bumper. Going to paint it after primer dries.
Dnrice is offline
Closed Thread
