Old 01-19-2013, 09:34 PM   #1
414banger
414banger's Avatar
disc brake master ?
if a guy was to do the disc brake swap could he still run the single non power master cylinder or have to go to a dual master cylinder
414banger is offline   Reply With Quote
Old 01-20-2013, 12:11 AM   #2
nachodog2
Hell yeah!!!
nachodog2's Avatar
Re: disc brake master ?
Definitely go to a dual with either a proportioning valve or adjustable valve for the rear brakes if keeping the drums.
Stock is good but custom is the sh*t!
nachodog2 is offline   Reply With Quote
Old 01-20-2013, 01:02 AM   #3
414banger
414banger's Avatar
ok thanks i might just rebuild the front drums for now then
Old 01-23-2013, 10:54 PM   #4
luvbowties
luvbowties's Avatar
Thumbs up Re: disc brake master ?
Replacing the single mc to the dual style was the 2nd thing I did to my '66. I think it is one of the safest things that I could do--it doubles your chances of surviving a blown wheel cylinder or line.
And nothing wasted(except maybe a $16-mc), as when you later go to discs, you will already have the dual system, lines, etc. [And, you can prolly be ok w/out a prop valve--at worst, should your rears catch too soon, you could install an adjustable valve on the rear line, like nachodog2 said above; this valve can be used when you later go to discs.]
You can buy a reman'd dual mc for about $16 from locals like A-Zone, Adv. A/P, O'Reilly's.
Luck to you,
Sam
luvbowties is offline   Reply With Quote
