body swap questions
ive got my daily driver 75 blazer, with rust. ive got a 75 jimmy with a very decent body. should swap, or should i cut the rust around the rear wheel wells and put in a fender flare? also, the jimmy has no body trim which i like, the blazer has big ugly trim. what to do? how hard would it be to swap them, how long would it take? is the electrical gonna be a downer? please input
I'd swap the bodys. It isn't as hard as it sounds. I swaped the cab on my truck in less than a day. The electrical should just plug in and go. Make sure you get a couple of friends to help you. I only had one person helping me (he was only there to help lift the cab).
"When I start my car in the morning I want the neighbors to think the world is comming to an end." Homer Simpson I'm not stuck, I've still got some gas left" |
how much do think the blazer body wieghs without the top?
i think i have alot of wiring going threw the firewall
"Texas is an outrage when your husband is dead, Texas is an outrage when they pick up his head, Texas is the reason why the presidents dead"-bullet by The Misfits |
![]() Join Date: Feb 2001
Wiring isnt that hard......The fuse block has a nut on the firewall side that lets ya disconnect the wires from the fuse block to the front. Theres a plug there also on the inside of the firewall for the wires going to the back.
If the other body is better I would switch them, better than patching in metal and using filler, should last longer. My.02
Chuck '85 Chevy Silverado 4X4 ![]() '91 Chevy 4X4 Suburban ![]() http://www.cardomain.com/memberpage/545941 |
#6 | |
