Old 02-14-2013, 02:04 PM   #1
Cali2Texas
need some info on lowering
i have a 83 chevy. i want to lower my truck, it already has 2 inch DJM coils in the front. The back has only 2 leaf spring thats how i got truck. i have look and look. what is a good drop for a daily driver truck ahd hauling stuff. i'm thinking of going with 3/5 or 4/5. can you give some info what are best brand to lower my truck. here some pictures as you can see the back lower then the front.
Cali2Texas is offline   Reply With Quote
Old 02-14-2013, 03:09 PM   #2
tinydb84
tinydb84's Avatar
Re: need some info on lowering
Are they drop leafs or did someone just remove a bunch? If they are just removed I would start by putting the correct number of leafs in.
Old 02-14-2013, 04:56 PM   #3
Cali2Texas
no i don't think they are drop leafs. but thanks for replying back. i got 28 views
Old 02-14-2013, 05:33 PM   #4
77ChevySharkBite
77ChevySharkBite's Avatar
best bet, I'm looking to do a 3/5 myself, as far as brands there's western chassis, belltech, and 1 other brand that I can't remember off the top of my head.
Most everyone goes with western chassis or belltech 2 very good quality brands. if you just have leaf springs in the back do a flip kit in the rear, and for the front just depends on what you want to do most people will do a 2" drop spindle and 1" drop spring. Hope it helps you out.
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 02-14-2013, 06:04 PM   #5
maxxxy
maxxxy's Avatar
For a daily driver,in the front I'd use drop spindles, probably a 2 inch spindle, and shackles and hangers in the rear. That should give you about a 4/5 drop.
I have Belltech spindles, they seem pretty well built.
Anything from Belltech and Mgaughys is going to be good, I have no experience with Western Chassis, so I can't say.
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 02-14-2013, 06:06 PM   #6
rs74
rs74's Avatar
How many leafs is a C10 supposed to have? Mine has 4.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 02-14-2013, 06:12 PM   #7
Cali2Texas
is DJM a good brand
Old 02-14-2013, 06:15 PM   #8
maxxxy
maxxxy's Avatar
DJM from what I hear is a pretty reputable company.
Max
Max's bagged 81
Old 02-14-2013, 06:20 PM   #9
Cali2Texas
it's has two leafs
Old 02-14-2013, 06:22 PM   #10
maxxxy
maxxxy's Avatar
If it were me, I'd add the correct number of springs in the rear first, because you wont be able to hardly put anything in the bed. Unless you are going to be using helper bags in the rear. In that case, you're fine how you are now.
Max
Max's bagged 81
Old 02-14-2013, 06:25 PM   #11
rs74
rs74's Avatar
What is the correct number of springs? Not trying to hi-jack. This may be useful to the OP as well as myself.
Roy
1987 R10 shortie
Old 02-14-2013, 06:28 PM   #12
TexasSteve
TexasSteve's Avatar
How are the roads in your area? Bad roads = nor much drop. Smoother the roads = the more drop you aan use on a daily driver. Not to mention....How much towing or carrying of heavy loads do you do? The less you carry means the lower you can go without having to do extra work (like a frame notch for rear axle clearance)/buy extra stuff (like air helper springs).
TexasSteve is offline   Reply With Quote
Old 02-14-2013, 06:28 PM   #13
77ChevySharkBite
Originally Posted by Cali2Texas View Post
is DJM a good brand
I don't have my truck dropped just yet but from what I hear most people will tell you to stay away from DJM, most guys will say Belltech, Western Chassis, or McGaughy's are 3 of the best to buy, everyone will have there own opinion though.
Korwin
Old 02-14-2013, 06:28 PM   #14
Cali2Texas
i really dont put anything heavy on the bed. i use to load my 4wheeler on bed. but i got trailer for that now.
Old 02-14-2013, 06:31 PM   #15
77ChevySharkBite
It just depends on the truck, I know for my 77 I have a total 4 leafs on each side totaling in 8 when combined so does my friends 76.
Korwin
Old 02-14-2013, 06:34 PM   #16
77ChevySharkBite
Cali2Texas, also whats your tire/rim combo your running or planning to run?
Korwin
Old 02-14-2013, 06:42 PM   #17
Cali2Texas
right now i have Hankook 275/60/15. planing on putting 20 inch rims on it later.
Old 02-14-2013, 06:44 PM   #18
maxxxy
maxxxy's Avatar
The trailer's tongue weight will still affect the "droop" of the suspension.
From what I can tell, the stock 2wd 1/2 ton comes in either 4 or 5 springs.
Unless you're carring feathers, if you want to use the truck at all like a truck, id suggest increasing number of springs.
Max
Max's bagged 81
Old 02-14-2013, 06:47 PM   #19
Cali2Texas
the roads are not bad. normal roads, yeah you have your dips here and there. i just don't want to go to low. but still have a nice clean look.
Old 02-14-2013, 06:49 PM   #20
77ChevySharkBite
In my honest opinion given what your going to be doing I know it might be hard but I would say hold off on dropping it for now, wait to put the 20's on there cause when you put the 20's you could do a static drop and be fine. I met a boardmember on here named DaddyO he hasa static drop on his and he uses his truck to do errands haul stuff simple truck duties. Again though its my advice not saying you have to listen but I'd hate for you to drop it and then mess up your truck you know?
Korwin
Old 02-14-2013, 06:56 PM   #21
meatwagon83
meatwagon83's Avatar
2 leaves arent going to haul much!!
meatwagon83 is offline   Reply With Quote
Old 02-14-2013, 07:08 PM   #22
Cali2Texas
thanks everyone for the great info, now i know what i need to do.
Old 02-14-2013, 09:23 PM   #23
lilpoindexter
lilpoindexter's Avatar
My shorty step side '78 straight six, three on the tree C10 had fo'
lilpoindexter is offline   Reply With Quote
Old 02-14-2013, 09:59 PM   #24
tinydb84
tinydb84's Avatar
I've got 8! But mines 3/4 ton. When I do my shackle hanger install I am going to 5.
Old 02-14-2013, 10:38 PM   #25
cory d
cory d's Avatar
halfs could be 3,5 and 8. not including the overload of course
cory d is offline   Reply With Quote
