Old 02-14-2013, 06:22 PM   #11
maxxxy
maxxxy's Avatar
Re: need some info on lowering
If it were me, I'd add the correct number of springs in the rear first, because you wont be able to hardly put anything in the bed. Unless you are going to be using helper bags in the rear. In that case, you're fine how you are now.
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
