Old 12-16-2012, 05:08 PM   #1
crustysarge
Where to find door weatherstripping
I am overseas and need door gaskets for my 72. I read a few posts about the style GMC Pauls sells but they won't ship to military APO so I need to find another source. Who makes/sells them?
crustysarge is offline   Reply With Quote
Old 12-16-2012, 05:49 PM   #2
72restorationvirgin
Active Member
72restorationvirgin's Avatar
Re: Where to find door weatherstripping
Maybe Wes at Classic Heartbeat will hook you up.
67 C20 283/4 Speed
72restorationvirgin is offline   Reply With Quote
Old 12-16-2012, 06:00 PM   #3
HotRod C/10
HotRod C/10's Avatar
summit or jegs has soft seals......good stuff!
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 12-16-2012, 08:49 PM   #4
leddzepp
Moderator
leddzepp's Avatar
I'd try Wes. I believe he sells the same ones GMCPaul does. They clip on, no gluing, awesome part.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-16-2012, 10:37 PM   #5
DonsCST
DonsCST's Avatar
PM me and I will provide you with my address, Have them sent to me, I'll rebox them with a USPS box and send them to your APO as a care package. No Charge- Thanks for your service to our country.
DonsCST is offline   Reply With Quote
Old 12-17-2012, 05:06 PM   #6
Square_78
Square_78's Avatar
If yu are stuck and need them, mid 90's I believe Dodge Dakota will work from an auto wrecker. Might be just as hard to find over there though..
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 12-17-2012, 05:31 PM   #7
weever82
weever82's Avatar
And thats why I LOVE this board!
The ones GMCpauls carries which are the BEST... are made by precision.
Weev-
Weev-
Life's tough...... It's even tougher when your stupid - John Wayne
weever82 is offline   Reply With Quote
Old 12-25-2012, 01:57 PM   #8
crustysarge
Thanks guys, I was on the road and just got home. I'll track some down from Precision.
Don, thanks for the offer but I have to make an order for other stuff as well.
Merry Christmas guys.
Old 12-25-2012, 04:37 PM   #9
brad_man_72
the boat guy
brad_man_72's Avatar
I've heard stuff from 99 up full silverado-suburban clip right in and are quite a bit nicer than stock. They have the corner molded in and are a little longer so all you have to do is trim them to fit.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 12-25-2012, 06:58 PM   #10
68gmsee
Active Member
68gmsee's Avatar
I bought mine couple of years ago from GMCPauls. At first the doors were somewhat hard to close so I had to adjust the striker out a little. After a summer they will mold to the door.
Leave a little more than needed at the bottom where the two ends meet. Maybe 1/4 inch. Mine seemed to have shrunk about that much but I think it was my fault for not pushing the corners in all the way. Overall, very pleased with them.
I bought window channel kit and seals at the same time and found out that with the cab sealed tighter it is easier to close the door slowly until there's about 6 inches left then push it faster to close it.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 12-25-2012, 10:14 PM   #11
1972RedNeck
1972RedNeck's Avatar
The OP's '72 should have a cab vent so it should close fine. That is a nice problem to have though. My cab corners provide plenty of ventilation.
Thank you much for your service.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 02-22-2013, 08:01 AM   #12
KyFarm
KyFarm's Avatar
I just bought weatherstrip from GMCPaul and it is made by "Precision" but it does not just clip on, absolutely needs glue.
Did I order the wrong part?
KyFarm's Build/Need help thread
1969 K-10, Short Step, (383HT/4L70E soon)-NP205
KyFarm is offline   Reply With Quote
Old 02-22-2013, 11:16 AM   #13
leddzepp
Moderator
leddzepp's Avatar
Sounds like it. I believe he carries both kinds.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-22-2013, 11:23 AM   #14
68gmsee
Active Member
68gmsee's Avatar
Correct pn is 2660241. Scroll down to view info: http://gmcpauls.com/Pickup.htm
06 Trailblazer
Old 02-22-2013, 05:17 PM   #15
KyFarm
KyFarm's Avatar
Thanks everyone, got the correct stuff on order
