Old 02-22-2013, 09:08 AM   #1
bradc2009
69 C10 5/7 drop
Ok guys, I've done my research and I cant figure out the rear suspension. I know i will need 2" drop spindles and 3" lowering springs in the front and out back i know i need 5" lowering spring and most likely a c-notch but i cant figure out how to get the other 2". I keep hearing about flip kits but from what I understand those are for leaf spring trucks, I have trailing arms and coil springs unless I'm missing something. Any info you guys can give me would be greatly appreciated. Thanks.
bradc2009 is offline   Reply With Quote
Old 02-22-2013, 09:19 AM   #2
CC69Rat
CC69Rat's Avatar
Re: 69 C10 5/7 drop
Contact Boris - his forum ID is Way2lo2 (I think) ?
You just need 2" drop blocks and longer U bolts. It will cost you about $100 for good ones (solid billet) Going that low I'd think about pinion angle, shock relocation, and track bar. (you may have already) I would also consider a 1 piece drive shaft conversion.
Do you have your notch kit yet? I'd highly suggest Porterbuilt stuff. Let me know if I can help you as I'm sure the other members will too. Welcome to the board from SE TN!
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 02-22-2013, 09:19 AM   #3
WIDESIDE72
WIDESIDE72's Avatar
Re: 69 C10 5/7 drop
You don't need a flip kit, since the Axle is already on tip, just blocks and longer u bolts. I have a CPP 3/4" spring drop on my 72 and it also included rear upper shock relocator brackets and adjustable track bar. I am running a later model 1 pc drivshaft as well. IMO any drop more than mine would need one of the aftermarket center cross member (where the carrier bearing was mounted). Good luck!
WIDESIDE72 is offline   Reply With Quote
Old 02-22-2013, 09:21 AM   #4
WIDESIDE72
WIDESIDE72's Avatar
Re: 69 C10 5/7 drop
I have heard that although the cpp cnotch is cheaper, the welds suck. You can search the forum in this regard.
Old 02-22-2013, 09:24 AM   #5
CC69Rat
CC69Rat's Avatar
Re: 69 C10 5/7 drop
Not saying mine is the ONLY way .. but check out the flip idea / Hotchkis brackets for the front of the trailing arm mounts on my GMC build (the second link in my signature) . This will help with the pinion angle issues as well, especially if you're staying with stock trailing arms (?) They are a ***** to get off, but if you simply flip the bracket upside down it will change the angle of the rear pinion in that your truck will only 'think' it has been dropped about 3". .. when in reality you're 6-7" drop.
The Porterbuilt CNotch is incredible. I happen to have the upper shock bar I will sell you if you decide to go that route. I just ended up with an extra.
Chad
Old 02-22-2013, 09:30 AM   #6
bradc2009
Re: 69 C10 5/7 drop
I was thinking about going with a 4/6 drop kit and then just buying a set of 3" drop spring for the front. I found a site that sells the kit with shock relocaters and all the other stuff to get the geometry right in the rear. But so what you guys are saying is drop blocks would be the best way to go. I just had a coworker say that I could clamp the spring but after some research I found that that's not a good idea. Thanks for your help guys I'm sure ill be back with some more questions.
Old 02-22-2013, 09:46 AM   #7
CC69Rat
CC69Rat's Avatar
Re: 69 C10 5/7 drop
Call Stan at Early Classics. He'll fix you up.
(mods, sorry about the ***) braindead this morning I guess. No disrespect intended, it just came out.
Chad
Old 02-22-2013, 10:51 AM   #8
bradc2009
Re: 69 C10 5/7 drop
i think early classics is where i found the 4/6 drop kit at that has everything to correct the geometry of the rear.
Old 02-22-2013, 11:47 AM   #9
leddzepp
Moderator
leddzepp's Avatar
Re: 69 C10 5/7 drop
What page of your build shows this "trailing arm flip"? Interested in seeing how it works, Thanks.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-22-2013, 03:08 PM   #10
cericd
cericd's Avatar
Re: 69 C10 5/7 drop
I first read about the "trailing arm flip" in gringoloco's C/10 thread - http://67-72chevytrucks.com/vboard/s...&postcount=908
Here's where gringo suggested it to Chad - http://67-72chevytrucks.com/vboard/s...510160&page=21
It is discussed throughout Chad's build from that point and the installation is talked about here - http://67-72chevytrucks.com/vboard/s...postcount=1044
but here's where we get to see so pics of the Hotchkis brackets installed - http://67-72chevytrucks.com/vboard/s...postcount=1053
fin
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 02-22-2013, 03:14 PM   #11
CC69Rat
CC69Rat's Avatar
Re: 69 C10 5/7 drop
Just to mention, flipping the brackets will make you loose about. 75" of your rear drop. But I think the trade off is worth it. Just a bigger drop block to offset
Chad
Old 07-01-2017, 03:52 PM   #12
Jlp18
Re: 69 C10 5/7 drop
Looking for some help. I bought a 69 gmc truck and want to lower it and make it level. I know I can do drop Spindel sin the front but the back I have leaf springs do I do drop blocks? Also what's the lowest I can go with out notching the frame and keeping the same geometry
Jlp18 is offline   Reply With Quote
