Old 03-06-2013, 11:34 PM   #1
dyno
dyno's Avatar
Fender Emblem Mounting...drill or silicone?
I restored my '80 Scottsdale 20 a couple years ago and never put the fender emblems back on, just filled the holes. I'm thinking my rig is having an identity crisis and I need to put them back on!
Now that I found a nice set of them on ebay, I'm wondering what most of you guys are doing to mount them. Drilling new holes or silicone in place?
"Built- not bought"
1958 GMC 150 4x4 in progress
1980 K20- Restored
1985 K3500 Flatbed
58 GMC 4x4 build thread:
http://http://67-72chevytrucks.com/vboard/showthread.php?t=557675
dyno is offline   Reply With Quote
Old 03-06-2013, 11:49 PM   #2
J Knight
J Knight's Avatar
Re: Fender Emblem Mounting...drill or silicone?
IMO, neither. All new vehicles are stick on and are tough to get off. I would use double stick 3M. It wont hurt the paint or sheet metal and if you change your mind you can remove it with fishing string.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 03-07-2013, 12:10 AM   #3
dyno
dyno's Avatar
The '80 "Scottsdale 20" emblem does not have a solid plate backing behind the letters to use double back tape on. It would show under the lettering unless I wanted to spend hours with a razor blade.
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
Old 03-07-2013, 12:15 AM   #4
dyno
dyno's Avatar
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
Old 03-07-2013, 12:56 AM   #5
AntiGov
AntiGov's Avatar
first off NICE truck....big pain but i think i would pull fenders and put them on correctly
88 3+3 454 400 205 410 drw to srw still in pieces
90 3+3 350 400 205 410 srw
84 1/2 ton lb 6.2 4x4 parts truck
AntiGov is offline   Reply With Quote
Old 03-07-2013, 01:09 AM   #6
cory d
cory d's Avatar
not running the 73-74 grille with 80 bezels could help
cory d is offline   Reply With Quote
Old 03-07-2013, 01:48 AM   #7
bigwheel15
bigwheel15's Avatar
Silicone, I couldn't find the heart to drill into a nice painted fender.
bigwheel15 is offline   Reply With Quote
Old 03-07-2013, 02:02 AM   #8
74 stepside
74 stepside's Avatar
Ive drilled thru fresh paint many times on customers rides when they added things. Its not too bad. Lay down some blue tape on the fenders and mark where you want to drill. The tape helps keep the paint from chipping around the bit. Or you can do the silicone thing...Im doing the same thing to my truck, adding the emblems. Mine were shaved years ago.
74 stepside is offline   Reply With Quote
Old 03-07-2013, 02:03 AM   #9
zaccaglin
zaccaglin's Avatar
There's. a product called "GOOP" they sell it everywhere in many different varietys. Get a tube of the Marine GOOP and use that, it sticks well, uv resistant, and its clear. I use it over silicon to make stuff watertight all the time.
Zaccaglin
1998 Chevrolet C1500 Ext. Cab 350
Former Rig:
1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208
zaccaglin is offline   Reply With Quote
Old 03-07-2013, 02:06 AM   #10
74 stepside
Maybe he just wanted to be different, like you, with a front bumper on the rear..
Old 03-07-2013, 06:03 AM   #11
bigguns
If the emblems have there studs just drill the holes and use the push in inserts that hold your emblems on. we use them all the time. No need to remove the fenders to install.
bigguns is offline   Reply With Quote
Old 03-07-2013, 10:47 AM   #12
88Jimmy4x4
88Jimmy4x4's Avatar
Could you be more specific on these inserts or post s pic or link?
Sounds interesting
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 03-07-2013, 12:46 PM   #13
bigguns
There called emblem barrel nuts http://www.ebay.com/itm/Ford-Lincoln...8b5f3f&vxp=mtr
