Old 03-26-2013, 11:25 PM   #1
papsoldblue72
papsoldblue72's Avatar
Question Lowering by doing a axel swap??
Ok I have a 1972 C-10 2 wheel drive truck it has the leaf spring set up.. My question ... Would it be possible to swap out to a newer model truck rear end that has leaf springs and disk brakes and in the process lower my truck by the rear end sitting on top of the springs instead of being mounted under them??? Has this been done before ???
It's been a long time coming... It's time to get it done..
papsoldblue72 is offline   Reply With Quote
Old 03-26-2013, 11:36 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Lowering by doing a axel swap??
DJM sells a "flip kit" for your existing rearend that will put it on top of the leaf springs.
No need to change to a different rearend.
Keith
Convert to disc brakes.
Old 03-26-2013, 11:37 PM   #3
lolife99
lolife99's Avatar
http://djmsuspension.com/products/fk-3/
http://www.summitracing.com/parts/dj...5/applications
Keith
Old 03-27-2013, 12:05 AM   #4
papsoldblue72
I have seen those done before but I was just thinking I could maybe upgrade to disk brakes and lower it a little cheaper this way also without having to do a lot of welding and fab work... IF it's possible at all... LOL
Old 03-27-2013, 12:09 AM   #5
TexasSteve
TexasSteve's Avatar
If the "new" rear end is set up for leafs under not over & the spring mounting pad is the correct width, then it'll be a simple swap. Otherwise you might have do a flip kit on the new rear end and/or move the mounting pads which means setting up for pinion angle & welding. Not to mention that swapping rear ends means dealing with brake line threads & emergency brake cable attachment.
2001 Yukon Factory Grey Metallic~2" DJM Key front drop/3" DJM Rear Springs~stock 16" chrome steel wheels~5.3/4L60E~Volante CAI w/under bumper air scoop~Magnaflow 10426 Bullet muffler~DDM LED all exterior lighting/55w-5000k HID Hi/Low/35w Fog
TexasSteve is offline   Reply With Quote
Old 03-27-2013, 12:45 AM   #6
papsoldblue72
So in a perfect world it might work..... LOL Great.... I would love to see some pictures if anyone has done something similar to this...
Old 03-27-2013, 07:46 AM   #7
andrewmp6
Even then you would have to change your master cylinder and proportioning valve to have rear disc brakes.
Old 03-27-2013, 10:43 AM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
It would be a lot simpler to do the flip kit and ad disc brakes to your current axle. Anything after 87 will have metric fittings for brakes and lugs,along with a different width.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-27-2013, 12:16 PM   #9
lolife99
lolife99's Avatar
Originally Posted by n2trux View Post
it would be a lot simpler to do the flip kit and ad disc brakes to your current axle. Anything after 87 will have metric fittings for brakes and lugs,along with a different width.
x2
Keith
Old 03-27-2013, 02:28 PM   #10
SCOTI
SCOTI's Avatar
Meaning much wider....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-28-2013, 12:03 AM   #11
INSIDIOUS '86
INSIDIOUS '86's Avatar
Out of personal experiance pleas don't go djm for a flip kit. Imported Chinese crap is all it is
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 03-28-2013, 12:23 AM   #12
papsoldblue72
x2
Ok it really isn't something I want to do but it looks as if it's the only choice I have... I really only want to get 3 or 4 inches lower and I see everyone getting these kits and hacking the frame up with those bolt in plates.... UUUUGGGHHH..... I was thinking instead of using those adapters on my old axel ... Why couldn't I use a different axel that already has the spring perches in the correct location for sitting on top of the springs... Maybe just maybe I wouldn't have to cut the frame up... I really don't know.... Probably would still have to cut it up....
Old 03-28-2013, 12:27 AM   #13
papsoldblue72
So where else ??? I would prefer U.S.A. How did you lower yours??? Or did you???
Old 03-28-2013, 09:28 AM   #14
SCOTI
SCOTI's Avatar
Check w/Early Classic Enterprises.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-02-2013, 12:29 AM   #15
AndrewSz
Well i think maybe you might have do a turn kit on the new back end and or move the increasing shields which indicates setting up for pinion position & welding. In addition to that changing back ends indicates working with braking mechanism line discussions & emergency braking mechanism wire connection . . . . .
AndrewSz is offline   Reply With Quote
Old 04-06-2013, 06:13 AM   #16
AndrewSz
rental cars surfers paradise
