Old 02-12-2013, 09:03 PM   #1
1972K20
1972K20's Avatar
5.3/4L60E 4wd Swap Questions
Ok, I've searched and read and searched and read, I've followed links, looked at build threads, read the pinned threads, PMed other members (thanks for the replies btw!) read sites like http://ls1tech.com and others for the last 3-4 weeks and gone in circles. With all the info out here the last thing I thought I needed to do was start a new thread, but he we go.
My plan is to do this to my 72 K5. I want to retain the original ride height and use the 4L60 w/the NP205. Also, I want to keep the original speedo, tach, oil pressure and amps gauges. My K5 has factory AC, and I want that to work too. I'm undecided on whether to retain the original power brake booster or switch to hydroboost. Any thoughts on that?
So, I decided that I should start looking for a donor engine/tranny to get started. This is where I have some questions.
-First and foremost, what is needed from the donor vehicle to make the swap successful? I know the complete wiring harness and PCM are needed. What else should I look for. I understand that if it's a DBW, I'll need the pedal and the TAC module. Am I forgetting anything here?
-Is there a better year than another when searching for a 5.3?
-When getting an engine from a salvage yard, or some other place where you can't hear it run, how do you determine if the engine is "good" by visual inspection alone?
These are the most basic questions, I know, but I want to make sure I have a good idea of where to start.
Thanks guys!
1972K20 is offline   Reply With Quote
Old 02-12-2013, 10:02 PM   #2
OldCreek
OldCreek's Avatar
Re: 5.3/4L60E 4wd Swap Questions
Sounds like you've done your homework....time to "dive in".
If you want a stock ride height you may have to move the engine back so that the pan has enough clearance from the axle differential. This would cause you to move the transfer case back and redo your drive lines....
You could pull the heads and oil pan to see the innards...or bolt it all together and fire it over. You could do a leak down test before hand or a compression test after you get it hooked up. It may be worth just hooking it up and seeing what you got.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 02-13-2013, 09:33 AM   #3
Clyde65
Clyde65's Avatar
My suggestion is this, before you buy your motor, make sure your ready for it, in other words, you have the time to devote to going through with the swap in the time the warranty period is. I didn't. I know that LS1nova makes or can help you with keeping your gauges so hit him up. make sure you get ALL the accessories from th donor ( best to buy the whole truck IMO). harness isn't real important if your not doing the electrical work anyway. I would get the motor that you can afford, the best one. most of the unwanted stuff (AFM and VATS et) can be modded out.
oh and we need pix, it isn't true unless you show pics dude!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-13-2013, 12:47 PM   #4
Thealien
Thealien's Avatar
My Jimmy had factory air and someday I plan on finishing the AC part of my swap.
I someday want to do the hydroboost but there is so much more to the swap that you should leave that for after the swap.
As far as what you should get, as much as you can. Engine, transmission, harness, PCM, pedal, tac, hoses, belts, assecories, starter, manifolds, section of exhaust with O2 sensors. These are the things that will nickel and dime you to death.
Some of the more reputable places to buy your engine will let you hear it run.
Old 02-13-2013, 01:17 PM   #5
OldCreek
OldCreek's Avatar
This is definately a "nickle and dime" you project.
There are a bunch of little things you need that the local stores don't have. Then, you have to order online, pay for shipping and wait a few days-week....painful.
Old 02-13-2013, 03:15 PM   #6
1972K20
1972K20's Avatar
Thanks for the feedback.
This is something I definitely want to do. I just want to plan it out the best I can before I start.
Old 02-14-2013, 12:14 AM   #7
solidaxel
solidaxel's Avatar
Keep us posted!!
I am at step #2!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-26-2013, 11:00 PM   #8
1972K20
1972K20's Avatar
Hey guys, I just wanted to come back to this thread with a question.
I found a 2002 5.3 w/harness and sensors for $185. However, the guys selling says the oil pump went out and it has lost compression and needs rebuilding. He also said no crack heads or block. When an engine loses compression, is it because the rings are bad or what?
What do ya'll think?
Old 03-26-2013, 11:14 PM   #9
solidaxel
solidaxel's Avatar
Keep looking !!!!
LS 3 4L70E
Old 03-27-2013, 06:38 AM   #10
Crash_OK
Crash_OK's Avatar
Originally Posted by solidaxel View Post
keep looking !!!!
x2
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 03-27-2013, 08:20 AM   #11
Clyde65
Clyde65's Avatar
move on dude!
Clyde65
Rebuild of Clyde
support our troops!
Old 03-27-2013, 08:23 AM   #12
Trsmotrhed
Trsmotrhed's Avatar
Originally Posted by Crash_OK View Post
x2
X3, you don't know what else is damaged.
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline   Reply With Quote
