Old 03-25-2013, 03:09 PM   #1
bucannon
Salty Sailor
bucannon's Avatar
Cool Let's See Some TWIN TURBO Setups
Lets see pictures of twin turbo setups in chevy trucks!
86 c-10 Custom Deluxe
Savannah, Georgia
bucannon is offline   Reply With Quote
Old 03-25-2013, 04:06 PM   #2
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: Let's See Some TWIN TURBO Setups
Man......I just trying to think of which one of my twin turbo setups I want to post!
prostreetC-10 is offline   Reply With Quote
Old 03-25-2013, 04:23 PM   #3
Schwinn
Schwinn's Avatar
Location: San Diego, Escondido, California, Del Dios Hwy
This is Josh Kalis's Camaro Twin Turbo 1200 HP
He is a great young man and my kids think he is cool.
http://skateboarding.transworld.net/...th-josh-kalis/
Schwinn is offline   Reply With Quote
Old 03-26-2013, 02:23 AM   #4
bucannon
Salty Sailor
bucannon's Avatar
That's an awesome setup, but what about some full size trucks! we have so much room in the engine bay for twin turbos!
Savannah, Georgia
Old 03-26-2013, 02:47 AM   #5
c-10ss
Not a twin setup but here's mine
PHP Code:
[PHP
[/PHP]Posted via Mobile Device
c-10ss is offline   Reply With Quote
Old 03-26-2013, 09:12 PM   #6
bucannon
Salty Sailor
bucannon's Avatar
Anyone ever heard of mounting them under the truck, ive seen it on corvettes at car shows and on some car in Hot Rod Magazine.
I also found this twin turbo setup on photobucket
http://s948.photobucket.com/user/Qui...1628a.jpg.html
Savannah, Georgia
Old 03-26-2013, 09:35 PM   #7
Str8-6-68
Str8-6-68's Avatar
my 02 twin turbo 5.9 cummins
12ram3500 HS mm, FP 5" tbe, SB cai, 2.5" up, 35s on 20s. SOLD 02ram2500 twin turbo, built 47re, sticks & studs : SIKDZL -youtube.
68gmc1500 soon to be: shortbox, ppumped 24valve, s467.7, dap 300s, H2O/Air intecooled, meth controlled, 47re, 14bolt, 2wd.
Str8-6-68 is offline   Reply With Quote
Old 03-27-2013, 09:42 AM   #8
SSC's76
No No
SSC's76's Avatar
[/url]
Yeah seen it done drove a Malibu with a single turbo like this not to bad. Some people don't like the idea cause its so far back there can be a delay in boost but it does provide a cooler charge since it has air flow the boost pipe acts like an inner cooler. Heck something is better then. Nothing in my book
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 03-27-2013, 04:20 PM   #9
bucannon
Salty Sailor
bucannon's Avatar
Cool Re: Let's See Some TWIN TURBO Setups
I can understand that it might have some delay but with the cooler charge does that produce more power?
Also...
Savannah, Georgia
Old 03-27-2013, 07:34 PM   #10
c-10ss
Every pound of boost is about 10% power gain roughly and about every 10 degrees colder is 1% in power gain. I am not a fan of the sts turbo kits. Turbos rely on heat to be efficient to spool up and u get mad boost drop with running the cold side pipes that long
Old 03-29-2013, 06:59 AM   #11
SSC's76
No No
SSC's76's Avatar
The way it was explained to me was it will create close to the same amount of power as having it mounted right off the exhaust manifold in the engine compartment. The only thing I noticed is when you let off the gas it does not blow off instantly that may have just been the setup on this car. There are pros and cons with every system. I've seen a lot of heat related turbo failures on trucks this issue would not happen with this setup.
Old 03-30-2013, 12:55 AM   #12
c-10ss
Ya if your fuel mixture leans out its bad news for everything , turbo setups need to run a bit on the fat side or meth injection ( which is what I going to be adding on to mine ) also the faster u can dump the exhaust after the turbo the better
Old 04-01-2013, 08:57 PM   #13
bucannon
Salty Sailor
bucannon's Avatar
We got alot of knowledge getting dropped, lets keep it up! anyone ever seen a twin turbo setup like this with the radiator mounted to the side?
Savannah, Georgia
Old 04-01-2013, 09:02 PM   #14
bucannon
Salty Sailor
bucannon's Avatar
Check out this sleeper!
Savannah, Georgia
Old 05-02-2013, 01:39 PM   #15
Wasted Income
Boosted Member
Wasted Income's Avatar
Is 260 rwhp considered a sleeper? lol.
Here's mine. Not twins, just a little single...
I'm kinda going for the whole sleeper thing too
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 05-08-2013, 01:31 PM   #16
bucannon
Salty Sailor
bucannon's Avatar
with a single turbo do you normally run it from both headers/manifolds?
seems like it would equalize back pressure
Savannah, Georgia
bucannon, twin turbo
