Old 04-07-2013, 11:49 PM   #1
Psycho_SWB
Painted my dash bezel and cab corner moldings this weekend
Getting all the little stuff ready while my truck is getting painted.
Spent most of this weekend masking, painting, then masking, then painting.
Psycho_SWB is offline   Reply With Quote
Old 04-07-2013, 11:52 PM   #2
rollin thunder
rollin thunder's Avatar
Re: Painted my dash bezel and cab corner moldings this weekend
good job. sweet looking corner trim peices
My build Lil` Red http://67-72chevytrucks.com/vboard/s...d.php?t=551373
1984 Chevy C10 short bed
2001 Chevy Impala police cruiser
2001 Chevy Silverado 1500 Z71 4wd extended cab dd
rollin thunder is offline   Reply With Quote
Old 04-07-2013, 11:56 PM   #3
Paul83
Paul83's Avatar
Those came out great. They look new. Good job.
Paul83 is offline   Reply With Quote
Old 04-08-2013, 12:24 AM   #4
AntiGov
AntiGov's Avatar
perfect color choice on those corners......looks great
88 3+3 454 400 205 410 drw to srw still in pieces
90 3+3 350 400 205 410 srw
84 1/2 ton lb 6.2 4x4 parts truck
AntiGov is offline   Reply With Quote
Old 04-08-2013, 09:05 AM   #5
BigMike608
BigMike608's Avatar
sweet, love the cab corners!
1977 SWB C10 - "Woodson": 5.3 Vortec LS Swap, 4L60e Trans, 4.5/5 drop
BigMike608 is offline   Reply With Quote
Old 04-08-2013, 09:38 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
nice work on the bezel
is it just repainted or did you do something to raise the texture
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 04-08-2013, 11:53 AM   #7
Psycho_SWB
Just repainted the dash bezel. In the second picture, it looks flat because I scruffed it up with a scotch brite pad. The third picture was after it was painted with SEM paint. Now I have to scruff up the black around the gauges again to apply my brushed aluminum applique.
Old 04-08-2013, 05:19 PM   #8
silvereagle07
silvereagle07's Avatar
That looks good. Must have taken a long time to mask those pieces.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 04-08-2013, 06:25 PM   #9
68Timber
I know the pieces fit
68Timber's Avatar
x2
The bezel looks good too but those cab corners are great.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 04-08-2013, 10:41 PM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
it looks really good
I want to fix mine ,and had thought of bedliner spray, for texure
John
Old 04-08-2013, 10:47 PM   #11
Psycho_SWB
Thanks. I spent most of the day masking and reverse the masking on the bezel. I don't think I would ever want to do it again, it was too tedious.
Old 04-08-2013, 10:55 PM   #12
Brockwaykid
Brockwaykid's Avatar
wow, nice job, love the corners.
Jeff Shaw
2003 Chevy 2500HD LB7 Duramax
Brockwaykid is offline   Reply With Quote
Old 04-08-2013, 11:32 PM   #13
INSIDIOUS '86
INSIDIOUS '86's Avatar
How did you clean up the silver over spray?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 04-09-2013, 01:17 AM   #14
lanconcj
lanconcj's Avatar
That looks great. How do you remove the cab corners? I am afraid of tearing mine up.
lanconcj is offline   Reply With Quote
Old 04-09-2013, 01:40 AM   #15
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Very nicely done!!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 04-09-2013, 11:32 AM   #16
Psycho_SWB
I sprayed the silver first since it was the toughest to mask off. Then I masked off the silver and sprayed the black, which cleaned up most of the silver overspray. Then I got a really fine brush and touched up any spots that were over or under-masked.
Old 04-09-2013, 11:34 AM   #17
Psycho_SWB
The cab corners have a 10mm nut that holds them in place. You have to reach underneath the opening from the inside of your cab corner to get to it. Once you take the nut off, just wiggle them slowly and they'll come apart and slowly slide apart from the rear cab molding. You have to use a little bit of care not to bend or twist them.
Old 04-09-2013, 02:08 PM   #18
INSIDIOUS '86
Ok so you did spray black. Make sense tell us how it holds up!
