Old 04-13-2013, 02:28 AM   #1
cameyer
lmc under bed tank help
So i started installing my lmc under bed gas tank today and need some help. can any one help me with what filler neck to use? the placement
really doesnt matter for now to me i will probably just bolt it to the bed i just really need to figure out what filler neck to use. Would a filler neck from a newer chevy truck work? Also can any one help me with where the other holes in the tank for the vent hoses should go. My tank in the cab only has one line going to the fuel pump with no vents.
cameyer is offline   Reply With Quote
Old 04-13-2013, 06:06 AM   #2
Chief Big Toe
Re: lmc under bed tank help
I had the same tank installed , But i no he mounted the filler neck in the bed , but it would shoot the gas out when being filled. so when it to the body shop , I had the guy put a 80 modle filler behind the rear wheel , I have yet to try it out,
Chief Big Toe is offline   Reply With Quote
Old 04-13-2013, 10:40 AM   #3
Rich 5150 69
Rich 5150 69's Avatar
To eliminate gas fueling issues your vent tube needs to come to the top of the filler tube...as shown.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 04-13-2013, 01:28 PM   #4
cameyer
looks like the filler hose is 1 3/8 in and the vent house is 5/8 in, any suggestions on what cars had this filler neck size?
Old 04-13-2013, 01:38 PM   #5
Rich 5150 69
The filler was from a Geo prism I believe, yes its one and three eights with a half inch vent hose, note the filler was cut and welded to fit my application, you`ll need to drill a hole horizontally thru the filler cap to create a vent hole sinse all new cars are not vented thru the cap, or put a pig tail vent on the tank underneath the bed.
