Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 04-16-2013, 03:03 PM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Fuel Pump Module
Originally Posted by SoCalSlaughter View Post
Well today I went to the junk yard to get a new pig tail for the oil sender unit, because the clip that holds it on had broken off, Once I put the new pig tail on, I tried to plug it into the oil sender and it wouldnt plug in, so I broke out the oil sender socket and took it off, and looked inside the socket and 2 of the pins where bent down and only the middle pin was straight and not jacked up. The truck ran with this unplugged, but would that keep the fuel pump from priming?
The way I read it the module overrides the ECM which shuts off the prime after 2 seconds or so and it continues to prime the injectors until the truck starts.
The oil pump sender should cutoff the module priming function after a certain pressure is reached. without the oil sender, the truck may have to crank longer to build enough pressure start. Honestly I haven't had much experience with these so maybe some others can explain it better.
I would say that you could get away with replacing the oil pressure sender and either wire around the hot module or replacing it. VV
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
ecm-b, fuel module, fuel pump, pump relay
