Old 04-26-2013, 11:41 AM   #1
Eliminator4life
Oil leak
So when I brought my truck home and the truck was running it would leak lots of oil above the oil filter. So I pulled the oil filter adapter off it had no gasket. So I went to get a gasket. Of course the place I go to says they don't make gaskets for them. So I buy a new one put it on go down the road. No leaks it's all good fast forward two weeks and its starting to leak lots of oil again from the same spot. Any guesses
Eliminator4life is offline   Reply With Quote
Old 04-26-2013, 12:13 PM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: Oil leak
I`ve never used one one but here is a thread o the chevelle site
http://www.chevelles.com/forums/showthread.php?t=312793
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 04-26-2013, 12:21 PM   #3
Eliminator4life
Re: Oil leak
I installed it properly I just cant firgure out why 2 weeks later its leaking
Old 04-28-2013, 03:13 PM   #4
luvbowties
luvbowties's Avatar
Smile Re: Oil leak
Check close that you do not have 2 outer ring/gaskets stacked one atop(below)the other. If one has hardened, it can easily make you think you are "feeling" metal when in fact you are feeling hardened, mis-shaped rubber--which could cause massive leaks about 2 weeks later.
Luck,
Sam
luvbowties is offline   Reply With Quote
