Originally Posted by n2billet
It's not a Sure Fit unit, it's a Gen II and I have it as high as I can get it...hope this helps you.
Originally Posted by longbed67
I have the gen IV sure fit vintage air unit, and moved it from the instructed mounting location to as high as it goes without modifying the cowl and it still hangs below about 4", even at this height you loose your entire glovebox. If you want it flush you would have to cut out your entire cowl, and run customs lines to the unit.
Thx to both of you for the info!
