Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 04-29-2013, 11:41 PM   #1
Z16
Everyone who uses BRAKE CLEAN should read this
I dunno if this has been posted before, but even if it has, it should be reviewed.
http://www.brewracingframes.com/id75.htm
A buddy sent this to me. I dunno if it's true, but I certainly will be more careful. I'm sure I've used brake clean before welding in the past.
98 GMC Sierra Ex Cab, cowl hood, Euro LED lights, 30 bar billet, Whipple Supercharged 350 Vortec: Forged flattops, E-Tec aluminum heads, Comp Cam, Scat crank and rods, Granatelli Mass air flow, Headers, Flowmaster exhaust , Complete MSD Ignition, Custom Tuning, intake spacer , ported throttle body, AC Delco port injection upgrade, Roller Rockers, Power Pulleys. Gear Vendors Overdrive. Soon to hit a dyno. 2/4 drop(for now).
95 Chevy S-10 Ex Cab 4.3 5 Speed 2/3 drop, Euro lights, billet grill, More to come. The Daily Driver
Z16 is offline   Reply With Quote
Old 04-29-2013, 11:56 PM   #2
mongoose
mongoose's Avatar
Re: Everyone who uses BRAKE CLEAN should read this
its true.. been there done that.
still alive tho.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 04-30-2013, 07:45 AM   #3
I did hear about that,but honestly I forgot. It's never bad to readdress a thing like this.
Old 04-30-2013, 09:06 AM   #4
alsriv2
alsriv2's Avatar
Location: Formerly MD and San Diego, now loving life in Arizona
Thank you for taking the time to share this with us. Maybe this should be posted in the main forum as well?
Alan
2012 Ram 3500 Dually Crew Cab 6.7 Cummins
2014 Palomino Columbus 340RK 5th wheel
'69 Chevy C10 396BB
alsriv2 is offline   Reply With Quote
Old 04-30-2013, 04:15 PM   #5
rambler
MOVE OVER
rambler's Avatar
wow. never knew this...
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 04-30-2013, 06:03 PM   #6
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Yeah this is true. I've experienced it and it isn't cool at all.
Ryan
1969 Chevy milk truck
Old 04-30-2013, 09:04 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Yep... almost lost a good friend from that exact scenario.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 04-30-2013, 10:17 PM   #8
JointTech
JointTech's Avatar
this thread is in the tools section as well. i remember reading it a while ago and telling my friend about it.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 05-01-2013, 10:40 AM   #9
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Thanks so much for the life-saving post Z16!
Most folks are vaguely aware of chemical reactions; ammonia & bleach,
oxygen & grease, etc but now that argon is becoming more common in
the home garage, it's doubly important to pay close attention when buying
and using chemicals.
Luckily, most Brake Cleaners are now "Non-Chlorinated". Be sure to
check the can when shopping and read the label!
ETsC10 is offline   Reply With Quote
Old 05-01-2013, 11:56 AM   #10
SigFTW
This is good to know, thanks for the info.
SigFTW is offline   Reply With Quote
Old 05-12-2013, 12:16 PM   #11
t300
Thanks for the post (this should be a sticky IMO, a lot of people don't know this.). When I got my Miller syncrowave a few years ago, first thing I did was grab the closest can of cleaner (which just happened to be chlorinated brake clean), cleaned up some aluminum and start welding. Noticed a funky smell, but kept going. Felt sick after. A quick google later and I've only used acetone since.
t300 is offline   Reply With Quote
