T10 or M20?
Comparing the two which is preferred. Asking opinions. I want a 4spd but cant find one. Saw a T10 needing rebuild for 250 on craigslist. Is it worth messing with?
-Mike- '94 GMT 400 ext z71 3" body, 3 in rough country, hd mirrors, 20" motometals on 35s |
Re: T10 or M20?
M20's are supposed to be weak. I had a M22 in my 66 Chevelle and it never broke. Beat the snot out of it too. People say the ears break off where they bolt to housing. I had mine bolted to a steel truck housing with the bigger clutch and it was Bulletproof. It got stolen one day:-(. I was looking for a replacement and was thinking about the t-10 too. They are also supposed to be weak unless you can find a "Super T-10". I LOVED my M-22 and I think we should be reunited. My .02c
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
Re: T10 or M20?
Both transmissions are about equal,if you ask me. No two things are exactly the same,but I'm saying where ever they differ won't matter. They were both used in muscle cars with the same power range. The Super T-10s and M22s are tougher,but the other boxes are plenty good. You can break anything.
![]() Join Date: Mar 2011
Re: T10 or M20?
M20's are supposed to be weak?? never heard that.
"back in the day"-----the m20 is a good 4 speed. If you are running a boat load of horsepower then go with the rock crusher (m22)--but Im telling you--its noisy, I know many "old" racers who used to use the m20 or m21 (close ratio) for drag racing behind 396's and 427's, 454's. You could power shift them all day, very seldom did you hear of one exploding or breaking. If your synchros get excessively worn from hard shifting, you might chip a few teeth. So, the t10 is a good trans. but dont ever be afraid of an m20 (now with all that said, I will also tell you that another good LOW horsepower option is the saginaw 4 spd. but if youve got over 300 hp, Id pass on that one) One final thought---a "good" m20 will cost you from 600 on up. Rebuilding one with new synchros isnt a hard job either. Personally, Im replacing a 700R with a '72 m20 in my current build.
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: T10 or M20?
I happen to like the M20 myself but Muncie is all my cars had..
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
Re: T10 or M20?
An M20 is not weak. I'd say a M20 is just as strong as an M21. An early 60's T10 is a tad weaker than the muncies IMO, but the ones I've seen have issues were in cars that got thrashed. Any trans can break in any car, just depends on how it's driven.
Re: T10 or M20?
Well ill have 375-400hp in a sbc. I really want to swap a m20 in if it could be found. Unfortunately 4 hrs after posting this thread i got to work and found out that i didnt have a job. They shut second shift down moved them to days and the young and less experienced,me only 21, wasnt needed. So now my truck is at a screeching hault. So no motor build no trans amd im getting married in two months. Im gonna try and find a cheap motorcycle forsale, and get a job at the new chevy dealership until i can figure out what to do. Kinda stuck between a rock amd a hard place
#8 | |
Re: T10 or M20?
Re: T10 or M20?
Sorry to hear about the job.
I think "weak" is a very relative thing with transmissions. If you beat the hell out of one, especially at the dragstrip, they will all fail eventually. Under normal street use, most will hold up just fine.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
#10 | |
Re: T10 or M20?
IMHO, it's more about gear ratios than anything else. The close-ratio boxes were intended for cars with lower rear end gears, shorter tires, less weight, etc....
You would have a hard time running one on the street and keeping the revs down on the highway at the same time. That 2.20 first gear is just not low enough
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
Re: T10 or M20?
I'm not much for 4spds but I kinda like mine. But I don't like going 55, I need speed. So I'm planning on Chevy's NV4500. Good tranny.
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses". ![]() 93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+ Members I've met... Mister-B |
Re: T10 or M20?
The very early M20 had a smaller cluster gear shaft which was prone to failure by breaking the case the later version had a larger shaft which was fine . I destroyed an early M20 in a 67 Camaro back in the day replaced it with a M22 until I put it up for sale then I installed a later M20 the guy who bought it beat that car to death and never hurt that trans.
Re: T10 or M20?
I did a quick search today and found that Gear Vendors makes an Overdrive unit for the Muncie m-series and the T-10. Now that would be fun! I think I will sell all my toys and look for Both for the dropped Blazer.
#14 | |
Re: T10 or M20?
#15 |
Re: T10 or M20?
http://www.gearvendors.com/hrgm4sm.htmlThis is soooooo cool.
#16 | |
Re: T10 or M20?
I've seen,and had,some powerful motors with 3spds behind them. It wasn't all 4spds back in the day. Sure,this is better than that,but any one you get can run the truck along just fine. I just bought a complete Saginaw 4spd set-up from an '80s van for not much $.
#17 | |
Re: T10 or M20?
