Old 04-03-2013, 03:54 AM   #26
SCHRUMGMC
SCHRUMGMC's Avatar
Re: May I see some headliners?
Originally Posted by OrrieG View Post
I gave you the link to the page in the spec manual that shows the orignal interior and exterior colors in another of your question threads. I also posted some original paint chip pages.
Yeah man I know Lol..Yeah I'll let you know if I have issues with it
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 04-03-2013, 05:39 AM   #27
OKGMC4
OKGMC4's Avatar
Steel bars with inserts, thin board assisted by aluminum strips (to be covered with 1/4 foam and cloth), finished headliner. Heat shielding glued in before install.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 04-03-2013, 08:50 AM   #28
Denee007
Denee007's Avatar
Thank you for posting your headliner pics! So, did you cut the headliner out of what, or did you purchase the headliner? And you did not use the rubber mounting that would go around the entire headliner to hold it up? The aluminum strips basically hold your headliner in place?
It looks great!!
'72 Ford Bronco project(July 17 2021-?)
https://67-72chevytrucks.com/vboard/...d.php?t=828015
59 Apache (sold 6-25-2021)
67 Ford Mustang (re-restored after Harvey)
1968 Jeep Cj5 (2-8-2020 to present)
1992 Jeep Yj (8-17-20 to present) (Jurassic build)
www.Classiccarsandtools.com
Denee007 is offline   Reply With Quote
Old 04-03-2013, 10:23 AM   #29
mknittle
mknittle's Avatar
It looks great!!
You can cut them out of "hardboard" from the lumber yard. Or if they don't have it the panels used for around shower/bath tubs works well.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 04-03-2013, 10:33 AM   #30
Denee007
Denee007's Avatar
Thanks, I think I have a piece of hardboard in the garage! I may play with that this afternoon~
Old 04-03-2013, 10:45 AM   #31
mknittle
mknittle's Avatar
Cool, Hardboard is also good for door panels, kick panels Etc. I do think if I lived in a humid or rainy climate I would use the water proof panels though.
Mark
My GMC build.
Old 04-03-2013, 02:55 PM   #32
OrrieG
OrrieG's Avatar
Originally Posted by Clarance J View Post
Hello Denee, When I put my headliner in I went with my seat colors. I first spray glued double sided foil insulation to help deaden noise. I started from the middle out using 3M Super 77. Its not real hard to do. The roughest part is deciding what kind of design to do. I know you'll show the forum what you decided on. With your truck color and interior color it will look great.
Clarance, did you use the factory gasket??
Old 04-03-2013, 02:56 PM   #33
OrrieG
OrrieG's Avatar
Good, I wanted to make sure you were seeing the information. Denee, sorry for the interruption!
Old 04-03-2013, 03:19 PM   #34
Denee007
Denee007's Avatar
No interruptions here~ I don't feel alone when folks are on my threads, everyone is welcome!
Old 04-03-2013, 04:24 PM   #35
SCHRUMGMC
SCHRUMGMC's Avatar
Don't worry BE happy
1971 GMC Sierra
1959 GMC 100
Old 04-03-2013, 10:56 PM   #36
OKGMC4
OKGMC4's Avatar
It looks great!!
I've always thought the gasket was kind of ugly so I wanted something different. Just didn't trust glue alone. There are nutserts on the steel strips inside the lip of the hole, and the bolts go through the aluminum and into the nuts so that when tight, the metal strips clamp together on the lip. The steel strips are siliconed in place at the ends to keep from sliding back and forth. I did end up pop riveting aluminum brackets on the ends of the board that slip inside the lip nearest the glass, because at speed with the glass down it would flop a little on the very ends. The heat insulation glued over lizard skin along with the 1/4 closed cell foam on the board make for a very quiet roof!
Old 04-04-2013, 12:27 AM   #37
Dan in Pasadena
Dan in Pasadena's Avatar
OKGMC4, I notice your interior body seams are filled. Did you weld them or did you use filler? How long ago and have you experienced any cracking?
Dan in Pasadena is offline   Reply With Quote
Old 04-04-2013, 06:06 AM   #38
OKGMC4
OKGMC4's Avatar
I welded them first so I wouldn't have to use as much filler, and to keep potential movement down. Kind of like taping a drywall joint before mudding to prevent a crack. It's been that way for about three years but I've only been driving it the last 7 months (3800 miles) with no problems yet. CAL58 did the same thing in his gmc a long time ago. His is the truck that inspired me to do mine that way.
Old 04-04-2013, 11:29 AM   #39
Dan in Pasadena
Ok thanks. I knew a guy many years ago with a very nice '56 that used Bondo only and his seemed to hold just fine; no cracks. Also there was an article recently in Rod & Custom (I THINK?) that also used filler, but a particular brand that was supposed to be extra crack-resistant. I've never liked how crude the interior seams looked.
Old 04-04-2013, 01:22 PM   #40
_Ogre
_Ogre's Avatar
denee; i used the same ultra suede cloth as i used on my seats. contact cement to stick the cloth to 1/8 foam. and contact cement to glue it to the roof. i wasn't able to get the stock rubber trim in after that. i used chrome door edge on the edge of the roof. i made a paper template 1 inch larger than the opening for the foam and cloth. i had tape to mark the center of the cloth and the opening. my wife helped me glue it to the roof, definitely a 2 person job. no pics of that part
shop air compressor timer
Old 04-04-2013, 01:37 PM   #41
Clarance J
Clarance J's Avatar
Hello OrrieG, Yes I did. Purchased from Classic Parts. It took about an hour with a little fighting but was worth it.
You have to have patiences or you'll be one.
Clarance J is offline   Reply With Quote
Old 05-08-2013, 09:10 PM   #42
Dan in Pasadena
I don't remember whose truck this is and it really is simple, but I liked the chrome door edge guard enough to save it to my computer.
Old 05-08-2013, 11:23 PM   #43
parkwood
parkwood's Avatar
One piece headliner in leather..
parkwood is offline   Reply With Quote
Old 05-08-2013, 11:34 PM   #44
mechanixman
mechanixman's Avatar
How'd you get the leather to stay?
Epoxy?
-Nick
Projects:
1952 Chevy 1 ton = The Build page
mechanixman is offline   Reply With Quote
Old 05-08-2013, 11:44 PM   #45
parkwood
parkwood's Avatar
Epoxy?
I didn't but the guy who does the interiors for me uses a glue made for doing interiors.. he's done a few for me this way and never had a problem and looks great.
Old 05-08-2013, 11:54 PM   #46
OrrieG
OrrieG's Avatar
Kustombrad used sign board plastic panels. He did a collage of old drag pics and had them vinyl them to the panels, then cut to fit. If I remember correctly I think he did the door panel the same way.
Old 05-11-2013, 12:22 AM   #47
JMR5
JMR5's Avatar
This is what I had in my 59. Really wish I would have pulled it out before I sold it actually.
JMR5 is offline   Reply With Quote
Old 05-11-2013, 02:12 PM   #48
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Here are a few!
ChuckDriver is offline   Reply With Quote
Old 05-11-2013, 02:13 PM   #49
ChuckDriver
3 more!
